Page 2 of 5 1 2 3 4 5
Re: Bill Mitchell Products. More Mopar blocks [Re: dthemi] #2719555
11/26/19 08:21 PM
11/26/19 08:21 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Originally Posted by dthemi
Originally Posted by fbs63
The main bulkheads are very thin below and between the cylinders.
I've only freshend one of these first hand so what I saw was as mentioned, weak in the web, and deck. I have seen 2 broken ones, and one so poorly machined that the rear main seal top, and bottom could not physically align.The broken ones were in spray use, but nothing a good mega block couldn't have taken (maybe 1400hp). Like without a diaper they could have ran the crank over. Some said it was sub par studs, but the look to me was weak block, in the deck too.
This is all true
Re: Bill Mitchell Products. More Mopar blocks [Re: ZIPPY] #2721732
12/05/19 03:52 PM
12/05/19 03:52 PM
Sweden
MikeN Offline
MikeN  Offline
Sweden
I can remember two actual complaints...some had paper thin spots that could be broken through easily with a sharp object.
(So that means a whole lot more than two were really out there)
The response from the ivory tower was, the product was developed using FEA, and the thin areas in the mains were, at that time, considered deliberate.
I was also given examples of several builders who deliberately opened up/machined away those thin areas which I was told was for a reduction in Windage losses.
This wasn't a debatable topic at that time, and these are not my ideas. The corporate Gods had spoken, LOL.
I'm just the messenger so don't shoot.
for the price charged, I'd prefer overbuilt rather than under.
If the block was computer designed, what strength was specified? Like peak cylinder pressure, torque etc.
Re: Bill Mitchell Products. More Mopar blocks [Re: MikeN] #2721737
12/05/19 04:17 PM
12/05/19 04:17 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The answer falls under the blanket of "proprietary information".
Note I'm not saying I agree with it, but this is what I was presented with at that time.
Rich H.
Esse Quam Videri
Re: Bill Mitchell Products. More Mopar blocks [Re: cuda499] #2721751
12/05/19 04:52 PM
12/05/19 04:52 PM
NW Indiana
P
powertrip Offline
powertrip  Offline
P
NW Indiana
This is all true
I e-mailed Bill Mitchell and got an immediate reply: These new blocks have been proven to 2000 HP with no issues.
Sounds strong enough for me, and comes without the Indy attitude, and the extra $1500 for a KB that you can't get anyway.
Re: Bill Mitchell Products. More Mopar blocks [Re: powertrip] #2721774
12/05/19 05:52 PM
12/05/19 05:52 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I have a new KB 4.500" bore hemi block (probably 7 years old) and a new Bill Mitchell 4.500" hemi block that I might sell soon. Also 2 NOS iron hemi blocks if anybody needs them. One is 4.500" bore mega block and the other is a 4.19" no lifter machining block. I guess like they use for Super Stock or other high output applications so they can spread the lifters. I live out in the country and am thinking about taking an extended leave of absence and getting a little antsy about leaving such easy to steal items laying out there while I'm gone.
2011 Drag Pak Challenger
Re: Bill Mitchell Products. More Mopar blocks [Re: rickseeman] #2721778
12/05/19 06:04 PM
12/05/19 06:04 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Just PM me your address and I will be happy to watch them for you wink
Re: Bill Mitchell Products. More Mopar blocks [Re: rickseeman] #2721784
12/05/19 06:21 PM
12/05/19 06:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How much for each
Re: Bill Mitchell Products. More Mopar blocks [Re: cudaman1969] #2721898
12/05/19 11:45 PM
12/05/19 11:45 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
I paid $6,000 for the SS block and I think $6,000 for the KB with freight and I believe $5,800 for the Bill Mitchell. I'm willing to sell them for what I paid. Someone already bought the other block.
Re: Bill Mitchell Products. More Mopar blocks [Re: GTX MATT] #2721899
12/05/19 11:45 PM
12/05/19 11:45 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
I would prefer that.
Re: Bill Mitchell Products. More Mopar blocks [Re: rickseeman] #2723146
12/11/19 01:07 AM
12/11/19 01:07 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
HI Rick,
Can you msg me the specs on the KB block, (what stage, water or solid, head stud size, lifter size and
spread, cam journal, is sleeve OD 4.630" or 4.700")anything else you might think of.
Thanks,
Ronny
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Bill Mitchell Products. More Mopar blocks [Re: powertrip] #2723745
12/13/19 02:09 PM
12/13/19 02:09 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
This is all true
There is no blocks to be had right now, KB or world. Indy doesn't either, and id rather spectate then give them money for that block that has issues staying cool and returning oil to pan.
Re: Bill Mitchell Products. More Mopar blocks [Re: cuda499] #2724238
12/15/19 05:42 PM
12/15/19 05:42 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Bill Mitchell had Hemi and Wedge aluminum blocks at PRI. World did not have an iron block there and an inquiry resulted in "how do you know about that?" and an explanation that they are in the works. No Bulldogs in sight anywhere that I saw.
Re: Bill Mitchell Products. More Mopar blocks [Re: CMcAllister] #2724279
12/15/19 07:20 PM
12/15/19 07:20 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Done
Re: Bill Mitchell Products. More Mopar blocks [Re: fbs63] #2724295
12/15/19 08:26 PM
12/15/19 08:26 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
What about?
Re: Bill Mitchell Products. More Mopar blocks [Re: rickseeman] #2724319
12/15/19 09:36 PM
12/15/19 09:36 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
What about?
Probably parts paid for and not delivered. A buddy of mine almost sent money a year ago, based on the information he was given (not by Bulldog) that the issues were resolved, others had received blocks in a timely fashion and a block was available for inspection at PRI.
He got cold feet .
Re: Bill Mitchell Products. More Mopar blocks [Re: CMcAllister] #2724334
12/15/19 10:53 PM
12/15/19 10:53 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Picture of guy leaving the PRI show on the Bill
Mitchell Facebook group page
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bill Mitchell Products. More Mopar blocks [Re: CMcAllister] #2724352
12/15/19 11:40 PM
12/15/19 11:40 PM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
So are you saying World is going to cast Iron Hemi and Wedge blocks?
Re: Bill Mitchell Products. More Mopar blocks [Re: KD800X] #2724365
12/16/19 01:15 AM
12/16/19 01:15 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's the scuttlebutt. No involvement from Tony. Seems to be early in the process. Guy I went with talked to them. I'll have to ask him if they said anything about an ETA.
Re: Bill Mitchell Products. More Mopar blocks [Re: pittsburghracer] #2724366
12/16/19 01:17 AM
12/16/19 01:17 AM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
That must be really late in the day, given the lack of people. Place was packed all 3 days.
Those are the main doors at the front of the hall. That's a high traffic area and the doors are closed. I'd like to know the details.
Re: Bill Mitchell Products. More Mopar blocks [Re: fbs63] #2724381
12/16/19 07:18 AM
12/16/19 07:18 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Back
