Dana 60 carrier #2723294
12/11/19 05:36 PM
12/11/19 05:36 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
So the carrier in the demon has decided to become open carrier. It has a trac lock unit in it and 30 spline axles. It is a dana truck housing cut down. The car makes around 650hp
would you guys step up to 35 splines axles and a 35 spline carrier or just get the yukon grizzly locker for it with 30 spline? The car has Doctor Diff 4340 axles in it.
The car is a street strip car
Re: Dana 60 carrier [Re: maxie] #2723302
12/11/19 05:54 PM
12/11/19 05:54 PM
What does the driver side axle splines look like now? If they're twisted it is time to change to bigger, stronger axle diameter, isn't it work
Re: Dana 60 carrier [Re: Cab_Burge] #2723345
12/11/19 08:35 PM
12/11/19 08:35 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I would not suggest a locker for anything other than mud boggers. Yukon makes an overhaul kit for your carrier. I used one in my pickup and it is actually a bit tighter than I would like for a truck, but would be great in a higher powered car.
Re: Dana 60 carrier [Re: TRENDZ] #2723431
12/12/19 11:52 AM
12/12/19 11:52 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If it was me and I was upgrading the axles I would just go straight to a spool and be done with it.
Re: Dana 60 carrier [Re: 340Cuda] #2723507
12/12/19 05:10 PM
12/12/19 05:10 PM
an8sec70cuda Offline
iagree 100%! Cheaper, lighter, stronger.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 carrier [Re: an8sec70cuda] #2723864
12/13/19 10:13 PM
12/13/19 10:13 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I spoke with Moser and Strange at the PRI show today. Both said that no more street use than the car sees they would recommend a spool with 35 splines axles.
I will probably go with Moser since I live about one hour south of them and they heavily sponsor our local track.
Re: Dana 60 carrier [Re: maxie] #2723898
12/14/19 12:52 AM
12/14/19 12:52 AM
The down side of a spool is you really need to make sure the tire circumference is within 1/4 inch on both rear tires, use the tire pressure to get it their up
I use to have to put new slicks in the sunlight for a while if the slicks varied more than 3/4 inch in diameter, pump up the small one with a seamstress tape around it to get them dead on (within 1/8 inch circumference) and let it sit in the Sun light for several hours and then let it down on the pressure to match the bigger one and go from there .if they shrank down more than within 1/4 at the same pressure do it again to get them to stretch to where you like it up scope
Re: Dana 60 carrier [Re: maxie] #2723916
12/14/19 07:19 AM
12/14/19 07:19 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have moser 35 spline axles in my D60 with a spool and couldn't be happier. I have logged lots of street miles with a spool and the only time its real even noticed is maneuvering in tight spaces.
My Jeep has a locker and it is more unpredictable, because it is either a spool, or an open differential. So if you are on a long sweeping turn and apply some power your open diff turns into a spool mid corner. That can be tricky in the rain, where as with a spool you know what you have all the time.
68 Barracuda Formula S 340
Re: Dana 60 carrier [Re: maxie] #2723992
12/14/19 02:29 PM
12/14/19 02:29 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
My car is running a cut down truck rear end as well. It was open . We rebuilt it adding a Powr-Lok clutch type unit and 35 spline Moser axles. It makes it easier to parallel park ! whistling
No complaints so far street or strip.
I am sure Moser gives sound advice.
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Dana 60 carrier [Re: maxie] #2723994
12/14/19 02:35 PM
12/14/19 02:35 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a Strange S-60 with a spool and 35 spline axles. As Bad340fish posted the only time I notice is maneuvering in tight places.
Re: Dana 60 carrier [Re: justinp61] #2724006
12/14/19 03:30 PM
12/14/19 03:30 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I have the S track in my s60, it works awesome for street strip car, has the helical gears,
Re: Dana 60 carrier [Re: CSK] #2724309
12/15/19 09:02 PM
12/15/19 09:02 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Any selectable locker is the best of both worlds.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 carrier [Re: CSK] #2724367
12/16/19 01:17 AM
12/16/19 01:17 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I put one in my Dakota, and that thing is terrific. I love how modulating the throttle will make it slip better on turns.
