Best Alternator / Starter RB 512 ? #2724228
12/15/19 05:07 PM
12/15/19 05:07 PM
Italy
Raffaplymouth60 Offline OP
Italy
Hello .. in my Cuda i have start problem at hot and low voltage . i have POWERMASTER starter and 100 ah alternator when everything is on and engine HOT the voltage go down at 11.8 volt ... not good if you stop the engine and wait 10 minute and start ... i have :
electric water pump
dual electric fans
Aeromotive A1000 Fuel pump
MSD 7 al
CVR electric brake vacuum pump
when headlight is on.... not good ...
i have checked all wire .. all ground ... replaced two alternators... no change..
need 150 ah alternator ?
best starter ? CR is 12:1
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Best Alternator / Starter RB 512 ? [Re: Raffaplymouth60] #2724234
12/15/19 05:29 PM
12/15/19 05:29 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
What cranking amp battery are you using? Are you using relays to fire up the accessories?
Re: Best Alternator / Starter RB 512 ? [Re: stumpy] #2724243
12/15/19 05:48 PM
12/15/19 05:48 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Sounds to me like you have more load than you have alternator to support it and it;s draining the battery to suppor the extra load.
You need to figure out how much all your electrical accessories are drawing, and if you really need all those thing to be electric, then get an alternator that can handle the load.
Re: Best Alternator / Starter RB 512 ? [Re: stumpy] #2724257
12/15/19 06:12 PM
12/15/19 06:12 PM
Italy
Italy
Optima 800 ah .. yes all relays
Re: Best Alternator / Starter RB 512 ? [Re: Sniper] #2724258
12/15/19 06:13 PM
12/15/19 06:13 PM
Italy
Italy
i think 80 ah for everything draw... need bigger alternator
Re: Best Alternator / Starter RB 512 ? [Re: Raffaplymouth60] #2724259
12/15/19 06:17 PM
12/15/19 06:17 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
100 amps but what is the ramp up to that 100amps? You need to find out what it puts out at idle and cruise before you can determine if it's right. If it never puts out those 100amps until 3500rpm then it won't do you much good.
My $45 cs130 for a Ford Tractor and my part store starter for a 318 worked better than any of the Powermaster alternators or starters I wasted my money on for my 451/472. Hot lapping and never missed a beat.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Best Alternator / Starter RB 512 ? [Re: Raffaplymouth60] #2724271
12/15/19 06:52 PM
12/15/19 06:52 PM
AndyF Offline
AndyF  Offline
Sounds like you need professional help. Find a repair shop with an amp clamp (or buy one yourself) and figure out what is really going on. Nobody on the internet is going to be able to solve it since we can't see how you have the wires routed and we can't debug anything. You need to use a volt meter and an amp clamp to find out what is happening. Most likely a wiring problem somewhere since 100A alternator shouldn't have an issue. Replacing multiple alternators tells me that you're chasing your tail.
Re: Best Alternator / Starter RB 512 ? [Re: Raffaplymouth60] #2724285
12/15/19 07:43 PM
12/15/19 07:43 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You need a modern charging system with an internal regulator like a Denso Toyota alternator. Like Andy posted you may have wire gauge issues or a system that is not designed for your current requirements. Modern cars of today have twice the amount of accessories taxing the electrical system and do it without any effort. You need a dedicated charging system wire harness in my opinion. Modern cars have several separate systems that are isolated from the other systems.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best Alternator / Starter RB 512 ? [Re: fourgearsavoy] #2724310
12/15/19 09:12 PM
12/15/19 09:12 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I chased my tail all summer with charging problems, I thought I had it solved with a new alternator, Then it wouldn't start again at a gas station.
I finally found out that the engine wasn't grounded good enough. One ground strap from the engine to the frame solved all problems. I know you mentioned you checked your grounds but make sure the engine is grounded very well.
Re: Best Alternator / Starter RB 512 ? [Re: fourgearsavoy] #2724313
12/15/19 09:18 PM
12/15/19 09:18 PM
AndyF Offline
AndyF  Offline
Correct, a 100A alternator that is hooked up to the original ammeter and feeding the charge thru the old firewall connectors is not a good solution. That is the problem with questions like this, there isn't anyway for the OP to tell us all the details of the installation. All it takes is for a bad wire or a bad ground or a poor connection somewhere and nothing will work correctly. I have a small 60A alternator on my Duster and it holds 14.5 volts even at idle. But all of my wiring is new and the alternator connects directly to the battery.
Re: Best Alternator / Starter RB 512 ? [Re: AndyF] #2724369
12/16/19 01:27 AM
12/16/19 01:27 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
That response was funny.
Re: Best Alternator / Starter RB 512 ? [Re: ProSport] #2724373
12/16/19 02:32 AM
12/16/19 02:32 AM
I called Power Master this summer about what size wire gauge from my 100 amp alternator after accidently grounding out the main wire while using a timing light power lead on it, that resulted in smoking and melting the 10 gauge wire all the way back to the battery puke
They recommended using a # 4 gauge wire along with using a #4 gauge ground wire from the treaded grounding boss hole on the alternator to a threaded hole on the block shock work
I'm going to do that this winter, in fact I'm going to run two #4 gauge wires from the alternator,, one to each battery up
Raff, I always slow charge my batteries for 10 to 30 hour with a 2 to 6 amp charger before taking the car to the races, that way I know they are fully charged to start with up scope
