73 to 74 A body trunk lock support?
#2723796
12/13/19 05:39 PM
12/13/19 05:39 PM
Posts: 5,664 South Dakota
hotairballoonpilot
South Dakota
Looking at AMD on the trunk lock supports. They list them for 70-73 duster's Does anyone know the difference between a 73 and a 74 in regards to the lock support panel? On this 74 I am going t be doing I will be doing the tail lighyt panel and trunk floor. The lock support panel on the car has been messed with before. It is usable but with some metal work. Was thinking that maybe if there rally was no major issues might be easier to go with a new one instead of messing with the old one.
Contact Me about AMD Prices
Re: 73 to 74 A body trunk lock support?
[Re: hotairballoonpilot]
#2723899
12/14/19 12:59 AM
12/14/19 12:59 AM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
I have an NOS one that was rivet inplace. I can get you the parts number on it and some pictures
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#2724497
12/16/19 02:44 PM
12/16/19 02:44 PM
hotairballoonpilot
South Dakota
that would be great if you could. i got reply back from Anna at AMD. she said that 73 and 74 show different factory part numbers and they never had a 74 to compare.
corey
#2724552
12/16/19 05:00 PM
12/16/19 05:00 PM
hotairballoonpilot
South Dakota
Looks like that center area is the big difference between the 2 lock supports, The new one is AMD 70-73 and the used one is on a tail panel I found listed on ebay saying it is for a 73-74 duster. Wonder if the 70-73 would work on a 74? Guess I will search out trunk locks and see if they are the same 70-74
#2724557
12/16/19 05:15 PM
12/16/19 05:15 PM
hotairballoonpilot
South Dakota
Lock cylinders I have seen list them 73-74 A body and the latches I am seeing are the same 62-74. Does that sound right?
