Hi Guys
I have a BAE 521 Hemi, it’s fitted with BAE stands and shafts and Stage V rockers, im trying to determine the correct way of setting up the stands and shafts, the shaft securing bolts have a long bolt at each end that pass through the shaft albeit loosely and the centre stands have short bolts that barely enter the shafts but also don’t fit though the shaft hole which helps hold the shaft from rotating but is bruised the tip of the bolt making it hard to remove through the alloy stand without damaging the thread. Any one had any experience with these???
