best RB 4.15 crank for the money? #2723484
12/12/19 03:48 PM
12/12/19 03:48 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
whats the best way to go for a RB 4.15 crank that is under $1500? shooting for the 750-ish hp range.
Re: best RB 4.15 crank for the money? [Re: chrisf] #2723487
12/12/19 04:17 PM
12/12/19 04:17 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have yet to hear anything bad about Monlar stuff....I have no personal experience with any of their stuff though.
Re: best RB 4.15 crank for the money? [Re: chrisf] #2723492
12/12/19 04:30 PM
12/12/19 04:30 PM
AndyF Offline
AndyF  Offline
Molnar has them in four flavors. 8/6 bolt and 2.2/2.375 pin. I'd highly recommend the 2.200 pin if you're buying rods at the same time. No good reason to use the extra heavy Mopar rods. I also don't think there is any reason to use an 8 bolt flange at 750 hp but sometimes you have to do what you have to do.
Re: best RB 4.15 crank for the money? [Re: AndyF] #2723501
12/12/19 04:53 PM
12/12/19 04:53 PM
Missouri
galen Offline
galen  Offline
Missouri
On my second Molnar crank and rods. 1st was a 3.91 with chevy journals and 6.7 rods B block.. Second is RB 4.5 with 7.1 rods. Machine work was spot on on both. Also the Molnar rods came standard with ARP 2000 bolts.
Re: best RB 4.15 crank for the money? [Re: AndyF] #2723502
12/12/19 04:55 PM
12/12/19 04:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Molnar crank and rods in mine. Toms great to deal with. Reasonable price. Spot on machining. Never dynoed mine but Wallace says 908 hp.
Doug
Re: best RB 4.15 crank for the money? [Re: dvw] #2723506
12/12/19 05:09 PM
12/12/19 05:09 PM
an8sec70cuda Offline
iagree I wouldn't hesitate for a second to use Molnar's products.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: best RB 4.15 crank for the money? [Re: an8sec70cuda] #2723509
12/12/19 05:18 PM
12/12/19 05:18 PM
IL
furious70 Offline
furious70  Offline
IL
I have an RB 4.15 2.375 Eagle crank from around 2006-07 still in a box on the shelf, how would it compare?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: best RB 4.15 crank for the money? [Re: furious70] #2723548
12/12/19 07:39 PM
12/12/19 07:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
As the owner of 2 Eagle cranks, I'd say yours should be checked for taper in the crank & rod journals and whether the snout where the damper fits is undersized.
Re: best RB 4.15 crank for the money? [Re: chrisf] #2723567
12/12/19 08:50 PM
12/12/19 08:50 PM
Call 440 Source and see how much their cranks are now scope
Why are you choosing that stroke instead of 4.250 stroke with the 2.200 rod journal sizes? work
Re: best RB 4.15 crank for the money? [Re: Cab_Burge] #2723619
12/13/19 01:10 AM
12/13/19 01:10 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I'm a huge fan of Molnar. Tom AND his parts. punkrocka
I've beat the crap out of his rods and crank and no issues.
'63 Dodge 330
11.19 @ 121 mph
Re: best RB 4.15 crank for the money? [Re: AndyF] #2723627
12/13/19 01:36 AM
12/13/19 01:36 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
iagree
Re: best RB 4.15 crank for the money? [Re: Cab_Burge] #2723678
12/13/19 10:47 AM
12/13/19 10:47 AM
BradH Offline
BradH  Offline
How's the Quality Control on 440 Source cranks these days? It wasn't very good to start with, IIRC.
Re: best RB 4.15 crank for the money? [Re: Cab_Burge] #2723681
12/13/19 10:55 AM
12/13/19 10:55 AM
BradH Offline
BradH  Offline
Not answering for the OP, but just an observation that a 4.15" x 2.20" combination could be a no-grind & drop-in deal.
Re: best RB 4.15 crank for the money? [Re: BradH] #2723702
12/13/19 12:10 PM
12/13/19 12:10 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
The 4.250 stroke 2.20 rod combo required no grinding in my RB block. I wouldn't bother with a 4.15 crank when you can get the 4.25 cranks for the same money and most likely not have any grinding to do. For the brand I have used 440 source, Molnar and Eagle and I have had no issues with any of them. Make sure you check them or have them checked by a machinist. I would buy who ever has the best price.
The only Carbs I care about are under the hood!
Re: best RB 4.15 crank for the money? [Re: Azzkikrcuda] #2723716
12/13/19 12:38 PM
12/13/19 12:38 PM
birdtracker Offline
birdtracker  Offline
Ohio Crankshaft. Birdtracker
Re: best RB 4.15 crank for the money? [Re: birdtracker] #2723725
12/13/19 01:04 PM
12/13/19 01:04 PM
BradH Offline
BradH  Offline
Originally Posted by birdtracker
Ohio Crankshaft...
Another company with a history of crankshaft QC issues. scope
Re: best RB 4.15 crank for the money? [Re: BradH] #2723727
12/13/19 01:09 PM
12/13/19 01:09 PM
birdtracker Offline
birdtracker  Offline
I bought a 4.25 crank from them. It was extremely spot on. Birdtracker
Re: best RB 4.15 crank for the money? [Re: birdtracker] #2723739
12/13/19 01:51 PM
12/13/19 01:51 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
My twocents
I would have the indexing checked on any crank that came over on the slow boat.
72 Plymouth Roadrunner 11.08@123.25
Re: best RB 4.15 crank for the money? [Re: birdtracker] #2723740
12/13/19 01:52 PM
12/13/19 01:52 PM
BradH Offline
BradH  Offline
Good to hear. There's been a lot of bad-mouthing of OC's products on SpeedTalk over the years that left me w/ the concern that their cranks can be seriously hit-or-miss on machining accuracy.
Re: best RB 4.15 crank for the money? [Re: BradH] #2723743
12/13/19 02:01 PM
12/13/19 02:01 PM
I've use 8 or more Ohio BB Mopar stroker cranks with no issues other than one got damaged in shipping work
