Re: best RB 4.15 crank for the money?
[Re: AndyF]
#2723501
12/12/19 04:53 PM
12/12/19 04:53 PM
Posts: 836 Missouri
galen
Missouri
On my second Molnar crank and rods. 1st was a 3.91 with chevy journals and 6.7 rods B block.. Second is RB 4.5 with 7.1 rods. Machine work was spot on on both. Also the Molnar rods came standard with ARP 2000 bolts.
[Re: dvw]
#2723506
12/12/19 05:09 PM
12/12/19 05:09 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I wouldn't hesitate for a second to use Molnar's products.
[Re: an8sec70cuda]
#2723509
12/12/19 05:18 PM
12/12/19 05:18 PM
Posts: 2,260 IL
furious70
IL
I have an RB 4.15 2.375 Eagle crank from around 2006-07 still in a box on the shelf, how would it compare?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2723548
12/12/19 07:39 PM
12/12/19 07:39 PM
BradH
I have an RB 4.15 2.375 Eagle crank from around 2006-07 still in a box on the shelf, how would it compare? As the owner of 2 Eagle cranks, I'd say yours should be checked for taper in the crank & rod journals and whether the snout where the damper fits is undersized.
[Re: chrisf]
#2723567
12/12/19 08:50 PM
12/12/19 08:50 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Call 440 Source and see how much their cranks are now ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Why are you choosing that stroke instead of 4.250 stroke with the 2.200 rod journal sizes? ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#2723619
12/13/19 01:10 AM
12/13/19 01:10 AM
Posts: 4,704 Wichita
GY3
Wichita
I'm a huge fan of Molnar. Tom AND his parts. ![punkrocka punkrocka](/ubbthreads/images/graemlins/custom/punkrocka.gif) I've beat the crap out of his rods and crank and no issues.
[Re: BradH]
#2723702
12/13/19 12:10 PM
12/13/19 12:10 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
The 4.250 stroke 2.20 rod combo required no grinding in my RB block. I wouldn't bother with a 4.15 crank when you can get the 4.25 cranks for the same money and most likely not have any grinding to do. For the brand I have used 440 source, Molnar and Eagle and I have had no issues with any of them. Make sure you check them or have them checked by a machinist. I would buy who ever has the best price.
The only Carbs I care about are under the hood!
[Re: birdtracker]
#2723740
12/13/19 01:52 PM
12/13/19 01:52 PM
BradH
I bought a 4.25 crank from them. It was extremely spot on. Birdtracker Good to hear. There's been a lot of bad-mouthing of OC's products on SpeedTalk over the years that left me w/ the concern that their cranks can be seriously hit-or-miss on machining accuracy.
