Re: Dana 60 carrier
[Re: maxie]
#2723302
12/11/19 05:54 PM
12/11/19 05:54 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
What does the driver side axle splines look like now? If they're twisted it is time to change to bigger, stronger axle diameter, isn't it
Re: Dana 60 carrier
[Re: Cab_Burge]
#2723345
12/11/19 08:35 PM
12/11/19 08:35 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would not suggest a locker for anything other than mud boggers. Yukon makes an overhaul kit for your carrier. I used one in my pickup and it is actually a bit tighter than I would like for a truck, but would be great in a higher powered car.
Re: Dana 60 carrier
[Re: 340Cuda]
#2723507
12/12/19 05:10 PM
12/12/19 05:10 PM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
If it was me and I was upgrading the axles I would just go straight to a spool and be done with it. 100%! Cheaper, lighter, stronger.
Re: Dana 60 carrier
[Re: maxie]
#2723898
12/14/19 12:52 AM
12/14/19 12:52 AM
Cab_Burge
The down side of a spool is you really need to make sure the tire circumference is within 1/4 inch on both rear tires, use the tire pressure to get it their I use to have to put new slicks in the sunlight for a while if the slicks varied more than 3/4 inch in diameter, pump up the small one with a seamstress tape around it to get them dead on (within 1/8 inch circumference) and let it sit in the Sun light for several hours and then let it down on the pressure to match the bigger one and go from there .if they shrank down more than within 1/4 at the same pressure do it again to get them to stretch to where you like it
Re: Dana 60 carrier
[Re: maxie]
#2723916
12/14/19 07:19 AM
12/14/19 07:19 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I spoke with Moser and Strange at the PRI show today. Both said that no more street use than the car sees they would recommend a spool with 35 splines axles.
I will probably go with Moser since I live about one hour south of them and they heavily sponsor our local track. I have moser 35 spline axles in my D60 with a spool and couldn't be happier. I have logged lots of street miles with a spool and the only time its real even noticed is maneuvering in tight spaces. My Jeep has a locker and it is more unpredictable, because it is either a spool, or an open differential. So if you are on a long sweeping turn and apply some power your open diff turns into a spool mid corner. That can be tricky in the rain, where as with a spool you know what you have all the time.
68 Barracuda Formula S 340
Re: Dana 60 carrier
[Re: maxie]
#2723992
12/14/19 02:29 PM
12/14/19 02:29 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
My car is running a cut down truck rear end as well. It was open . We rebuilt it adding a Powr-Lok clutch type unit and 35 spline Moser axles. It makes it easier to parallel park ! No complaints so far street or strip. I am sure Moser gives sound advice. Mark
Re: Dana 60 carrier
[Re: justinp61]
#2724006
12/14/19 03:30 PM
12/14/19 03:30 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I have the S track in my s60, it works awesome for street strip car, has the helical gears,
Re: Dana 60 carrier
[Re: CSK]
#2724309
12/15/19 09:02 PM
12/15/19 09:02 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Any selectable locker is the best of both worlds.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Dana 60 carrier
[Re: CSK]
#2724367
12/16/19 01:17 AM
12/16/19 01:17 AM
Posts: 2,725 541 slobovia
A990
541 slobovia
I have the S track in my s60, it works awesome for street strip car, has the helical gears, I put one in my Dakota, and that thing is terrific. I love how modulating the throttle will make it slip better on turns.
