BB oil pump base gasket. Can't find online. #272343
03/31/09 10:34 AM
03/31/09 10:34 AM
Dallas, Wisconsin
BurntOrange Offline OP
Dallas, Wisconsin
I can find the o-ring for the cover and the pressure relief bolt gasket but not the base gasket unless I buy a new , rebuild kit or pump.
Does any one stock them or do I need to make one. It's leaking bad and I dont want to torque the bolts any more than I have. This engine will be coming out later this year, but I need to keep it running and not leaking too bad till then. Do dealers carry them? All the parts stores in my area don't.
Re: BB oil pump base gasket. Can't find online. [Re: BurntOrange] #272344
03/31/09 10:46 AM
03/31/09 10:46 AM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
MoPar pn is 2084355. List is $5.65, also has the orings in it.
This space available for rent
Re: BB oil pump base gasket. Can't find online. [Re: cptn60] #272345
03/31/09 01:11 PM
03/31/09 01:11 PM
Dallas, Wisconsin
Dallas, Wisconsin
Thanks!
Re: BB oil pump base gasket. Can't find online. [Re: BurntOrange] #272346
03/31/09 01:24 PM
03/31/09 01:24 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
BurntOrange
Give Dale @ Chenoweth Speed & Machine a call (309) 266-8084 and ask for the Superformance Products part #1306. I will venture to say that is is less expensive than the Mopar unit and the gasket material quality is the best I've seen available for this. It's even Non-Stick and can be reused and doesn't require any sealer.
Re: BB oil pump base gasket. Can't find online. [Re: BurntOrange] #272347
03/31/09 01:58 PM
03/31/09 01:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: BB oil pump base gasket. Can't find online. [Re: BurntOrange] #272348
03/31/09 03:19 PM
03/31/09 03:19 PM
AndyF Offline
AndyF  Offline
Cometic makes an oil pump gasket that works really well. It is a multi-layer gasket rather than just a thin paper one.
