70 RR front marker light hardware
#2723296
12/11/19 05:42 PM
12/11/19 05:42 PM
Posts: 2,092 New Mexico
JMCFAN
New Mexico
Came up empty at Ace... looking for u nuts and screws to mount front marker lights to fender....?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR front marker light hardware
[Re: gtx6970]
#2723344
12/11/19 08:29 PM
12/11/19 08:29 PM
JMCFAN
New Mexico
The ones i have have two holes for mounting studs...the fastener guide shows U nuts etc...???
[Re: Sammy]
#2723346
12/11/19 08:37 PM
12/11/19 08:37 PM
JMCFAN
New Mexico
Have you tried R/T Specialties Tom is the owner. Sent a email! Thks
[Re: a12rag]
#2723349
12/11/19 09:04 PM
12/11/19 09:04 PM
JMCFAN
New Mexico
here is the NOS kit that I opened up to have a look . . . happy hunting . . .
U nuts go onto fender and then the housing is screwed to fender . . . then the reflector is snapped in place. The electrical socket is held in place on the studs with the nuts with captive washer that digs into back of socket for good ground. Man thanks!! I just need the U nuts and the associated screws....!!
[Re: JMCFAN]
#2723351
12/11/19 09:07 PM
12/11/19 09:07 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
U nuts go onto fender and then the housing is screwed to fender . . . then the reflector is snapped in place. The electrical socket is held in place on the studs with the nuts with captive washer that digs into back of socket for good ground. Man thanks!! I just need the U nuts and the associated screws....!! Most welcome ! always great to see another FC7 B body on the road !!!
[Re: a12rag]
#2723352
12/11/19 09:10 PM
12/11/19 09:10 PM
JMCFAN
New Mexico
U nuts go onto fender and then the housing is screwed to fender . . . then the reflector is snapped in place. The electrical socket is held in place on the studs with the nuts with captive washer that digs into back of socket for good ground. Man thanks!! I just need the U nuts and the associated screws....!! Most welcome ! always great to see another FC7 B body on the road !!! Soon....
[Re: burdar]
#2723453
12/12/19 01:39 PM
12/12/19 01:39 PM
JMCFAN
New Mexico
Unless something has changed, you likely won't get a response. The best way to contact him is to call. Tom is/was a one man operation and doesn't answer emails. Thanks!!
[Re: burdar]
#2723455
12/12/19 01:44 PM
12/12/19 01:44 PM
JMCFAN
New Mexico
Unless something has changed, you likely won't get a response. The best way to contact him is to call. Tom is/was a one man operation and doesn't answer emails. Score!! Shipping today!!
[Re: Matt M]
#2723571
12/12/19 08:59 PM
12/12/19 08:59 PM
JMCFAN
New Mexico
Here is another one. V-Code 4 Speed [/quote] Beauty! If I was not going numbers matching I would have ditched the vinyl top.....but I still like the wing...unlike a lot of folks....
