Re: Valve lash kill and thrill [Re: BradH] #2723235
12/11/19 01:22 PM
12/11/19 01:22 PM
central il.
second 70 Offline
second 70  Offline
central il.
Tighter makes it look like a bigger cam, loser makes it look smaller. correct?
Re: Valve lash kill and thrill [Re: BradH] #2723253
12/11/19 02:53 PM
12/11/19 02:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
BradH Thank you for your link and other input!I just wanted to be sure to say that.I changed my lash .008 tighter from .020 spec and will go back as a A B A test
Re: Valve lash kill and thrill [Re: second 70] #2723255
12/11/19 02:57 PM
12/11/19 02:57 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Yes. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Valve lash kill and thrill [Re: Clanton] #2723261
12/11/19 03:33 PM
12/11/19 03:33 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There are of course limits.
Too loose will destroy the parts, the tappet is not the only location of slack.
Too tight is only dangerous one way: the valve does not close. A valve left open .002" stops working, and says so (DV).
Boffin Emeritus
Re: Valve lash kill and thrill [Re: polyspheric] #2723298
12/11/19 05:51 PM
12/11/19 05:51 PM
I've own and driven a V.W powered sand rail for a lot of years, I ended up buying motor parts from several different off road racers in SO CA to make it faster. In the process I learned from them that all air cool V.W. motor have solid lifters and the factory spec of setting the lash cold at .0040 was to loose, those racers suggested setting them at .0000 or just tight enough to be able to still
rotate the pushrod by hand , but not easily, just barely able with two fingers to rotate them at outside air temps when cold work That worked well on that motor up
I did find out on my last pump gas motor with a set of Harland Sharp 1.65 ratio single shaft rocker arms that combination of parts on that motor the lash would only change by .0010 from room temps to 180F shock shruggy
Re: Valve lash kill and thrill [Re: Cab_Burge] #2723677
12/13/19 10:47 AM
12/13/19 10:47 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have read that a .010 tighter lash was equal to 1pt in compression less for someone trying to adjust for lower octane so would a looser lash be a gain in 1pt cr?
Re: Valve lash kill and thrill [Re: Clanton] #2723680
12/13/19 10:52 AM
12/13/19 10:52 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That statement makes far too many assumptions for me to put any faith in it, regardless of the source.
Re: Valve lash kill and thrill [Re: BradH] #2723847
12/13/19 09:04 PM
12/13/19 09:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Right. And what "compression"? I guess because were adjusting valve timing with lash adjustments, it must mean dynamic "compression". And of course the collective "we" cannot even agree on exactly what valve position we should use to calculate dynamic compression. All that said, I cannot see it changing dynamic compression 1 pt.
I do know that my motor will blow 5 psi more with 0.004-5" lash added.
