You can believe it or not, but you're moving the valve open and closing points slightly. The engine idled 50-75 RPM higher and was just a little more crisp without touching anything else. It's like moving your cam timing a half or 1 degree.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
