Re: Why did my Cam Fail????
[Re: fbs63]
#2723221
12/11/19 12:45 PM
12/11/19 12:45 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For a BB Mopar?
Cast cores used with roller lifters are made of a different material than what is used with flat faced tappets.
AFAIK, there are no SADI cores(ductile iron, the material used for roller lifters) made to fit BB Mopars.
[Re: markz528]
#2723234
12/11/19 01:21 PM
12/11/19 01:21 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
My biggest thing is to make sure that the new motor cam does not experience any issues..............
I wouldn't personally run a 5150 core with those specs. You would have better reliability out of an 8620 core but of course need to make sure spring pressure and everything else in the valvetrain is correct. JMO
[Re: fast68plymouth]
#2723239
12/11/19 01:27 PM
12/11/19 01:27 PM
Posts: 4,105 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
There are no cast roller cores for BB Mopars.
Copper color between the lobes is 8620 material. Black between the lobes is usually 5150 material.
The heat treat goes deeper on the 5150, which allows for more manipulation for putting a wider variety of lifts and LSA’s on the core.
Both are steel billet. Yes, his was a steel billet but likely (99.99%) it was as Fast said 5150 base. I vaguely remember him saying that Comp would offer him no $break$ for a replacement and they did say that the 8620 SHOULD have been HIS request for his application AND would be a $ upcharge verses the 5150 cores.
[Re: HardcoreB]
#2723248
12/11/19 02:05 PM
12/11/19 02:05 PM
fast68plymouth
So. Burlington, Vt.
I haven’t had any problems with the 5150 cores. That’s what most of the BB Mopar cores are these days. They simply don’t always have 8620 cores that are suitable for every combination. And if they do, they’re usually more $$$.
Unless Marks cam looks way worse in person than in the pics...... I still say it looks pretty normal to me.
[Re: fbs63]
#2723304
12/11/19 06:00 PM
12/11/19 06:00 PM
Posts: 43,360 Bend,OR USA
Cab_Burge
I've had some hydraulic rollers I would swear were cast. Years ago, early to mid 1970s, I had two Isky solid rollers that I'm sure where cast core camshafts also ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) None bought since from any other company ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: BradH]
#2723312
12/11/19 06:19 PM
12/11/19 06:19 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
I'm DOOOOOOOOOOOOOOOOOOOOOOOOOOOOMED!!! I have a BLACK CORE CAM!!! ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) ( Hee hee! ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) ) NOOOOOOOOOOOOOOOOOOOOOOOO,, dont take it apart & start over ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
[Re: n20mstr]
#2723358
12/11/19 09:24 PM
12/11/19 09:24 PM
Posts: 4,293 Morrow, OH
markz528
Morrow, OH
Is BES ok with reusing that cam? Maybe now is the time to let him spec your new one ? The cam is being replaced. New one is on its way. That was always the plan.
[Re: markz528]
#2723408
12/12/19 10:07 AM
12/12/19 10:07 AM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
If it's still straight and otherwise in good shape, might be a nice one to regrind, if there's enough meat there in the right places to create a different profile.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2723554
12/12/19 07:56 PM
12/12/19 07:56 PM
markz528
Morrow, OH
Looked at it some more tonight.
It’s the worst on the opening side. At max lift not too bad and gets worse on the closing side but not as bad as the opening side. Base has no marks.
The worst groove is 0.0008 inches - so almost a thousandths. I actually thought it would be worse.
The worst ones have pretty significant burrs.
[Re: A727Tflite]
#2723581
12/12/19 09:27 PM
12/12/19 09:27 PM
markz528
Morrow, OH
Have you compared the width of the contact portion of the roller wheel versus the edges of the contact patch on the lobe? I have not but it looks to be pretty much the width of the roller.
[Re: markz528]
#2723596
12/12/19 11:07 PM
12/12/19 11:07 PM
markz528
Morrow, OH
Some additional pictures showing the damage better.
[Re: markz528]
#2723633
12/13/19 02:29 AM
12/13/19 02:29 AM
Cab_Burge
it looks like one side of that lifter is hitting the cam lobe before the other side, it looks like it is loosing contact with the lobe after max lift ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I would replace (or have them rebuilt with new wheels, axles and bearings) all the lifters off of the lobes that look like that ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: BradH]
#2723687
12/13/19 11:13 AM
12/13/19 11:13 AM
fast68plymouth
So. Burlington, Vt.
Still looks totally normal to me. The more pics I see the more normal it looks.
All 16 lobes on the cam I posted the pic of have the same impressions on the opening side, in the area where the big change in velocity and pressure angle occurs.
Anyone got a pic of a typical drag race roller cam, that’s been run with typical drag race spring pressures for 100 or more passes that doesn’t have those marks on the opening side? Let’s see some pics and specs.
#2723697
12/13/19 11:54 AM
12/13/19 11:54 AM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
.0008 Give me a break. 😂 Lmao
[Re: pittsburghracer]
#2723941
12/14/19 11:17 AM
12/14/19 11:17 AM
Posts: 2,530 PA
moparacer
PA
I have a Bullet cam that looks just like that. And it eat a lifter and screwed it up....I could take some pictures and you wouldn't be able tell them from yours. When I first switched from a solid to a roller in my big block it was even worse. We sent the cam back to Bullet and they checked the hardness and it was ok, reground it, I put it back in and it did it again. I ended up upping the spring pressure and it helped, but I don't think I ever totally eliminated it. Since then I have been through several different lifter styles, cams and even blocks and it has always done it to some extent. I have to pull the engine and go through it here shortly and its got a few hundred passes on it and I bet there is some evidence of it still doing it.
I would like to know what the issue is if anyone ever figures it out. I have a theory that it might be related to the roller diameter, lobe profile and the geometry of the lifter bores, but that is just a guess.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
