My dad is in the middle of restoring his numbers matching fj6 70, 340, 4spd cuda. Got the car all apart. He wanted me to ask you in the know, what's the exact color that is used or should be used for the inside window trim parts. Semi gloss or ?? Black interior color. Thanks Ryan
The factory painted it in suede black. Not legal in too many States and the current formula is a little off so you need to be careful spraying it so you don't get too much texture.
The Ditzler Part number is 9388 - go to a PPG dealer and they can translate.
