Wiring can be tedious, time-consuming, and a terrifying part of a restoration. Some of you may have been stranded by the dreaded melted bulkhead connection and cooked voltage regulator or probably heard of someone that has. There is nothing worse than being stranded while cruising in your classic Mopar. While these problems aren’t monumentally difficult to fix, they can leave you stranded along the roadside just the same. With a little help from our friends at YearOne and Mancini Racing, rewiring your Mopar could not be easier.
Read the whole story at Mopar Connection Magazine HERE:
