Re: issues with fresh 440
[Re: moparx]
#2723245
12/11/19 01:49 PM
12/11/19 01:49 PM
Posts: 461 Detroit Michigan
stinger
Detroit Michigan
I switched from fram to wix and thats when the issues started
[Re: stinger]
#2723246
12/11/19 01:59 PM
12/11/19 01:59 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If it has as little run time as I’m thinking, the “issue” of the cam/lifter going away began as soon as the engine was fired for the first time(or even before that).
[Re: topside]
#2723315
12/11/19 06:23 PM
12/11/19 06:23 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
There are A LOT of junk counterfeit Wix oil filters out there, they look just like the real thing, & yes fram filters are junk.
