Re: Are there any "small" OEM BB crank pullies?
[Re: BradH]
#2722019
12/06/19 01:03 PM
12/06/19 01:03 PM
Posts: 4,680 Wichita
GY3
Wichita
As in smaller than standard, but not as small as the Moroso cast pulley? What's wrong with the Moroso pulley? I run it on the street and never have any cooling issues.
[Re: BradH]
#2722029
12/06/19 01:25 PM
12/06/19 01:25 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The smallest factory crank pulley I've seen is 6 1/4" in diameter and 2" high to the center of the V.
[Re: GY3]
#2722035
12/06/19 01:52 PM
12/06/19 01:52 PM
BradH
As in smaller than standard, but not as small as the Moroso cast pulley? What's wrong with the Moroso pulley? I run it on the street and never have any cooling issues. Other people who have used the Moroso pulley have said they had cooling issues because of the reduced water pump speed, so I'm not 100% confident it's the way to go. I'll do some more research based on everyone's responses above.
[Re: John_Kunkel]
#2722037
12/06/19 01:52 PM
12/06/19 01:52 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I'd have to check out the diameter of the March I've been running, I know it was smaller than the stock pulley. Mancini lists a crank pulley at 5.2"
72 Plymouth Roadrunner 11.08@123.25
[Re: BradH]
#2722078
12/06/19 04:43 PM
12/06/19 04:43 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I can build you a pulley in any configuration you want if you can supply the needed dimensions.
[Re: TRENDZ]
#2722157
12/06/19 10:25 PM
12/06/19 10:25 PM
Posts: 10,006 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There is another company that makes beautifulreduced size pulleys for mopar, including crank, water pump and alternater pulleys. For the life of me i cant remember thier name, but they sure looked good on the 408 i built! I think they were out of Minnesota? Google aluminum pulleys and see what pops up.
[Re: gregsdart]
#2722234
12/07/19 09:35 AM
12/07/19 09:35 AM
gregsdart
If you decide to go aftermarket, TRENDZ (Rick) can make a nice piece that will give you the exact speed you want to run an alternater, etc at. He made a double for me for my bracket car that turned out very nice!
[Re: BradH]
#2722293
12/07/19 01:36 PM
12/07/19 01:36 PM
gregsdart
Off the top of my head...
Looks like OEM replicas are listed as 6.25"... about an inch wider in diameter than some of the aftermarket pulleys I found.
Not sure what diameter the Moroso is, only that it says a 30% reduction in pulley speed, IIRC. My brain hasn't shifted into calculator mode to reverse-engineer the diameter. To figure what i needed i took the max alternater rpm. As my target, then from the alternater pulley diameter and my max engine rpm i came up with the size pulley i needed. Since most all of us run more rpm at cruise than a stock setup it works well for the water pump also. Mymax rpm on the 408 was 6200 and a 5 inch pulley was about perfect. I had 3.55 gears and an auto.
[Re: BradH]
#2722348
12/07/19 04:50 PM
12/07/19 04:50 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
Not sure what diameter the Moroso is, only that it says a 30% reduction in pulley speed, IIRC. My brain hasn't shifted into calculator mode to reverse-engineer the diameter. .
Reduction will be directly proportional to diameter.
[Re: BSB67]
#2722359
12/07/19 05:49 PM
12/07/19 05:49 PM
GY3
Wichita
The Moroso is 5". Funny aside about the Moroso pully: I do my best to hide any aluminum and aftermarket mods in my engine compartment. I installed the aluminum pulley out of the package thinking it was buried to where no one would really see it. I went to a local cruise spot and literally the FIRST guy that walks up and looks at the engine points and says "Oh, it looks like you have an underdrive pulley!" I went home, ripped off the pulley and immediately painted it black!
