Re: 1970 Coronet 1/4 skins
[Re: patosmith]
#2719770
11/27/19 03:08 PM
11/27/19 03:08 PM
Posts: 1,281 WI
wannadrag
WI
AMD all the way. AMD doesn't make one for a 70 Coronet and I am not buying a 69 panel to hack up and hope it works.
[Re: copchaser]
#2722415
12/07/19 10:16 PM
12/07/19 10:16 PM
Posts: 1,281 WI
wannadrag
WI
Pay real close attention to the side marker light stamping. I ended up having a die made to correct the stamping. They look good and the lights fit,the bumper recess doesn't match up with the 1/4 extension so some tweaking for sure
[Re: wannadrag]
#2722504
12/08/19 11:52 AM
12/08/19 11:52 AM
Posts: 1,179 Canada
demon
Canada
The “Sherman” 70 quarter skins are pretty pathetic. They are flimsy, have rounded folds at the door jamb etc, and are actually oversized, because like all of those older skins, they were designed as a quick fix to slide over top of the original panel. But that’s the only thing available. I will take the AMD 69 quarters and modify them for my 70. At least the AMD panels are thick gauge and accurate stampings.
[Re: demon]
#2722640
12/08/19 08:35 PM
12/08/19 08:35 PM
Posts: 1,281 WI
wannadrag
WI
The steel thickness is exactly the same as factory I checked it,amd doesn't make a 70 panel so a 69 wouldn't be accurate either The “Sherman” 70 quarter skins are pretty pathetic. They are flimsy, have rounded folds at the door jamb etc, and are actually oversized, because like all of those older skins, they were designed as a quick fix to slide over top of the original panel. But that’s the only thing available. I will take the AMD 69 quarters and modify them for my 70. At least the AMD panels are thick gauge and accurate stampings.
