Old school Mallory tach repair #2721402
12/04/19 04:11 PM
12/04/19 04:11 PM
oregon
greendart408 Offline OP
oregon
I grew up looking at my dads early 70s circa 3 5/8s rev limiter with shift light tach in his cars. I recently got my original 69, 340, 4spd swinger going in day two vibe. Part of that was needing THAT tach, my wife bought it for me for Christmas last yr to finish off the vibe of my car. I used it one yr and worked perfect. Went drag racing with the car and you guessed it, the ol trusty tach didn't like the rev's apparently lol. My question is where do I send it to have fixed? Have called multiple places online with no luck. I know auto meter has a repair place for their stuff but haven't had any luck with the Mallory..... It works but the needle is erratic and is obviously not right. Shift light still works etc etc. I have checked all the obvious wiring stuff, thanks
Re: Old school Mallory tach repair [Re: greendart408] #2721405
12/04/19 04:26 PM
12/04/19 04:26 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I believe RobbMc on here used to work for Mallory..he might know.
Re: Old school Mallory tach repair [Re: Hot 340] #2721466
12/04/19 08:43 PM
12/04/19 08:43 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Autoinstruments in VA. Just redid my old hustle stuff dixco tach. Works like a new tach.
Re: Old school Mallory tach repair [Re: Jeff_383] #2721610
12/05/19 10:15 AM
12/05/19 10:15 AM
oregon
oregon
Thanks for the options guys, I will check them out.
Re: Old school Mallory tach repair [Re: greendart408] #2721710
12/05/19 02:59 PM
12/05/19 02:59 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
You may want to look into retrofitting an updated circuit board. Erratic/inaccurate needle operation could depend on the ignition system you're using. Sometimes the modern MSD type ignitions don't play well with tachs that were originally intended to be used with dual point or early transistorized systems.Swapping in a modern circuit board could ostensibly solve the issue.If it's got power and ground, there's probably not much inside that can be 'fixed' beyond getting another one.
If you can get beyond the portraits on the main page, maybe see if this guy can help.
Tachman
'71 Duster
'17 Ram 1500
Re: Old school Mallory tach repair [Re: RMCHRGR] #2721910
12/06/19 12:51 AM
12/06/19 12:51 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
That's what autoinstruments do. Modern circuitry in the old tach. You could try an ebay small 8k tach and carefully remove your tach face, place it on new tach and mount the new small tach in foam, that is then placed in the old tach case.
Re: Old school Mallory tach repair [Re: greendart408] #2721917
12/06/19 02:28 AM
12/06/19 02:28 AM
I was told about a automotive instrument repair shop in Tacoma or Seatle that does old car instrument repairs along with the more common repairs, I can't remember the shops name now but they told me about another speciality shop down in L.A.,CA for after market Sun electrical instrument repairs like I wanted done. I ended up buying new VDO instruments for that car instead of spending more for the repairs than the new ones cost shruggy work
I do have one older (mid 1970 to mid 1980s or so) Mallory electric tach that the needle fell off that I may have done for my 1963 Plymouth Fury some day once it is back in line for finishing luck
Re: Old school Mallory tach repair [Re: Cab_Burge] #2721972
12/06/19 10:12 AM
12/06/19 10:12 AM
AZ
squirrel Offline
squirrel  Offline
AZ
cable drive is the only way to fly smile
