Have you considered converting your manual steering to a power assisted system? If so, has the thought of searching for suitable used or remanufactured factory power steering components and brackets caused you to shy away from attempting such a task? You could install a complete aftermarket system, but what other systems in the engine bay will have to be modified to fit the power steering (K-frame, accessory belt system, hydraulic hose routing, etc.)?
Read the whole story at Mopar Connection Magazine HERE:
