This cam w/power brakes-general street manners
#272132
03/30/09 11:30 PM
03/30/09 11:30 PM
Posts: 381 Denver CO
bennydodge
Denver CO
Anybody here try this solid flat tappet cam before?: Lunati #404A3LUN
Advertised duration(int/exh): 282/282 Duration at .050: 255/255 Valve lift: .582/.582 LSA/ICL: 108/102 Valve lash: .016/.016 RPM range: 3500-7200
This would be going in my 416 stroker SB w/11.5 to 1 comp., Eddy heads. Lunati says it's the "largest cam recommended for a daily driver". I want to run 3.23 gears with it also. I've also got power brakes. What do you guys think? Lunati also recommends some fairly mild springs too- 120lbs closed 265lbs open. Doesn't seem right. Anyone try this setup before? I'm really leaning towards trying this cam since I already have it. Opinions are not only welcomed, they are encouraged.....
73 Challenger 340(416),E-heads, 727, 3.23 SG 2015 Challenger R/T classic B5, wife's car 2010 Ram 3500 Crew Cab SLT dually 4X4 2016 Challenger Hellcat Redline Red A8
Re: This cam w/power brakes-general street manners
[Re: bennydodge]
#272134
03/31/09 12:33 AM
03/31/09 12:33 AM
Posts: 1,261 ILL
mark7171
ILL
[Email]255@.050[/Email] duration... and you want to turn a 3.23 ? You are depending on your crank throw to spin the difference.
That cam would like 4.10 + in the rear. Not for driving around with your buddies either. Might be a fun drag car.
For the street cams stay around .440-.460 lift.
[Re: mark7171]
#272135
03/31/09 04:51 AM
03/31/09 04:51 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
not sure on how the hydraulics compare to the solids...I've been told yo ucan't make a direct comparison...
but I have a 275 advertised duration, 235ish @ .050, .525 total lift, and it had enough vacuum for brakes, but its also in a "low deck 440."
I did have it with a 3.23 gear, and I could never use 5th gear, with 4th gear being 1:1 and 28.5" tall tires, It would turn 2300 or so at 60. shift into 5th and I had to drive faster than 70MPH to get it so it would stop surging and lugging.
Also had to slip the clutch a lot just to get going, and it made for very painful, slow parking lot driving.
**Photobucket sucks**
[Re: bennydodge]
#272137
03/31/09 09:46 AM
03/31/09 09:46 AM
Posts: 3,905 Minnesota
3twos
Minnesota
I can't imagine this cam would have enough vacumn for power brakes. You may want something with less duration if it is a street car, especially with 3.23 gears.
Al & Sheila
[Re: mark7171]
#272140
03/31/09 11:48 AM
03/31/09 11:48 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
um, lift really is only a secondary/tertiary spec when it comes to drivability. duration determines powerband range, and that is variable depending on size of the motor and compression.
a [Email]255@.050[/Email] degree solid will be comparable (after lash) in manners as a [Email]240-245@.050[/Email] hydraulic. the "3500-7000" RPM powerband really is bogus, the cam & powerband will be COMPLETELY different in say an 8:1 273 or 318 than in a 11.5:1 408. given it's a symmetrical camshaft, you also have a little less overlap (66 degrees) than if you had a dual pattern cam.
personally I think it'll be a pretty good cam for your combo (high compression, big cubes). IIRC GmachinedartGT is running a [Email]250-255@.050[/Email] solid roller in his eddie headed 408 dart with 2.94 gears and it works great for him, can keep up with freeway traffic at reasonable RPM's, IIRC gets close to 18mpg on the highway, all while being able to click off low 12 second quarters...
I think you'll be fine for a hot street car, I'd swagger probably around 9" vaccuum in gear, which should be fine for PB....if you wanted to try get a little better low RPM manners out of it, you could run a looser lash (effectively making it appear a few degrees smaller) or maybe install it at 100 ICL instead of 106. with that much compression you might need the extra duration of the cam to kill off a little cylinder pressure so you don't get into detonation with pump gas. might want to post this question in the race forum for some other points of view.
[Re: patrick]
#272141
03/31/09 12:07 PM
03/31/09 12:07 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
I have a MP 484 cam (241/241 dur @0.50, .484/.484 lift, 108 lsa) in my 9.5:1 417 stroker. I have power brakes and it pulls about 11" of vacuum. I would say 98% of the time the brakes work just fine and I feel comfortable driving the car. You just have to be careful with the stop and go driving in heavy traffic due if the vacuum in the booster is low from a previous brake and has not built back up it is much more difficult to stop the car in an emergency type situation. But like I said 98% of the time not a problem. Also I have 3.91 gears in my 4-speed 70 Cuda and it is a really blast to drive.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: patrick]
#272142
03/31/09 05:51 PM
03/31/09 05:51 PM
bennydodge
Denver CO
These were my thoughts as well, Patrick. When I had the MP .474" hyd. cam in this same combo it made torque like my Cummins diesel, so I'm thinking I can run a cam this aggressive with these gears and get away with it.
Anybody else wanna' chime in?
