Anyone ever use a non lockup torque converter #2720862
12/02/19 12:31 PM
12/02/19 12:31 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Pros and cons?
Re: Anyone ever use a non lockup torque converter [Re: Sammy] #2720866
12/02/19 12:46 PM
12/02/19 12:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Uuuuhhh, I would say that most racers use non-lock up converters.
Re: Anyone ever use a non lockup torque converter [Re: fast68plymouth] #2720870
12/02/19 12:57 PM
12/02/19 12:57 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Aren't the majority lock up converters?
I thought 1/8th mile fast guys are using non lock up?
Re: Anyone ever use a non lockup torque converter [Re: Sammy] #2720873
12/02/19 01:06 PM
12/02/19 01:06 PM
So. Burlington, Vt.
So. Burlington, Vt.
A “proper” lock up converter has a clutch in it that’s activated by the transmission.
You need both a lock up converter, and the trans to go with it.
So...... no one running a regular 727 or 904 is using a lock up converter.
Unless there’s some current technology for those transmissions I’m not familiar with.
Re: Anyone ever use a non lockup torque converter [Re: Sammy] #2720874
12/02/19 01:08 PM
12/02/19 01:08 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
No, like Dwayne said most everyone uses a non-lockup. But, the really fast turbo/Nitrous/outlaw types have recently started using them.
Neal Chance
Billet Lockup Racing Converters
Starting at -$7,300.00
The latest innovation from Neal Chance Racing Converters is the Full Billet Internal Lock Up Racing Converter. This unique new converter was a top secret joint project between NCRC and Rossler Racing Transmissions, but the cat is out of the bag now! This converter has captured and HELD ALL the Turbo World Records and ALL the Pro Nitrous Records in PDRA!!!
It works either with a TH400 Based Transmission such as the 3 speed, 2 speed TurboGlide, Ty-Drive or Bruno Drive. The Lockup Converter offers far more durability than a “Dry” clutch, with the ability to last an entire season in a 3.70 Nitrous car with no wear!
'71 Duster
'17 Ram 1500
Re: Anyone ever use a non lockup torque converter [Re: RMCHRGR] #2720875
12/02/19 01:14 PM
12/02/19 01:14 PM
So. Burlington, Vt.
So. Burlington, Vt.
Perhaps the OP is confusing “non-lock up” with “spragless”??
Re: Anyone ever use a non lockup torque converter [Re: fast68plymouth] #2720880
12/02/19 01:29 PM
12/02/19 01:29 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
shruggy
'71 Duster
'17 Ram 1500
Re: Anyone ever use a non lockup torque converter [Re: RMCHRGR] #2720895
12/02/19 02:16 PM
12/02/19 02:16 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The last few episodes of No Prep Kings have been mentioning them...
Re: Anyone ever use a non lockup torque converter [Re: topside] #2720908
12/02/19 03:28 PM
12/02/19 03:28 PM
WA
JD Dart Offline
JD Dart  Offline
WA
You need a power adder in order to gain any ET benefits my little 499 wouldn't recover from a 700 rpm drop from the highest load going down the track from increased wind friction for example I shifit into lockup at 7250 rpm drops to 6550 that puts me at 7.28 seconds into a 8.87 run now the motor only has 1.59 seconds to recover some and increase mph my thought it would just stall there and maybe get up to 6600-6650 mph would be down from a non lockup run.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Anyone ever use a non lockup torque converter [Re: fast68plymouth] #2720916
12/02/19 03:40 PM
12/02/19 03:40 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
...So...... no one running a regular 727 or 904 is using a lock up converter.
ugh???
Both transmissions got the factory lock-up functionality around '78 I think (give or take a year?).
As applicable to drag racing I would agree that most probably run non lock-up setups. However, I for one have a lock-up 518 here and would consider running a high-stall lock-up converter in it. I haven't gotten anywhere near actually being able to prep the transmission and make the appropriate changes to use that setup in my coupe, but one of these days I would consider doing so.
Re: Anyone ever use a non lockup torque converter [Re: Diplomat360] #2720918
12/02/19 03:44 PM
12/02/19 03:44 PM
So. Burlington, Vt.
So. Burlington, Vt.
I thought the transmissions got a different number designation when they went to the lock-up.
Like a 904 was a 999, or something like that.
In any case, you need a transmission that has the capability to operate the lock up clutch for it to work.
Edit: I see there are in fact lock up 727’s and 904’s....... which would be used with specific clutch equipped converters for that feature to be operational.
Your typical TA 10”, Dynamic 9.5”, 8” ATI Treemaster, etc....... are non-lock up.
Re: Anyone ever use a non lockup torque converter [Re: Sammy] #2720922
12/02/19 03:49 PM
12/02/19 03:49 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I have a lock-up converter in my A340E OD transmission.
The box will take 800 hp, the converter clutch will take 350.
Boffin Emeritus
Re: Anyone ever use a non lockup torque converter [Re: polyspheric] #2720964
12/02/19 06:00 PM
12/02/19 06:00 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
All the torque multiplication goes away once you lock up the converter so when used in a race application you better be bringing plenty of torque with you...as stated earlier a "Power" adder motor. Not too many (if any) Naturally aspirated motors will pick up with one.
2spd w/lockup converter
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Anyone ever use a non lockup torque converter [Re: Diplomat360] #2720972
12/02/19 06:24 PM
12/02/19 06:24 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Originally Posted by Diplomat360
ugh???
Somewhere in the back of the shed I have a big-block 727 lockup trans and converter I decided to squirrel away at one time. I believe it's a '78. 727s and 518s could be had either way but 904 variants were all lockup from some point on.
Re: Anyone ever use a non lockup torque converter [Re: W.I.N. Racing] #2720983
12/02/19 07:14 PM
12/02/19 07:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It's already gone when the car rolls out.
Boffin Emeritus
Re: Anyone ever use a non lockup torque converter [Re: polyspheric] #2720984
12/02/19 07:18 PM
12/02/19 07:18 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
My new Chance 8 inch NSX all aluminum converter is non lock up.
I was worried that it wouldn't be good for 1/4 mile racing.
Re: Anyone ever use a non lockup torque converter [Re: polyspheric] #2720985
12/02/19 07:23 PM
12/02/19 07:23 PM
A727Tflite Offline
A727Tflite  Offline
It doesn’t immediately “disappear” after you leave the starting line.
