Anyone ever use a non lockup torque converter
#2720862
12/02/19 12:31 PM
12/02/19 12:31 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Re: Anyone ever use a non lockup torque converter
[Re: Sammy]
#2720866
12/02/19 12:46 PM
12/02/19 12:46 PM
fast68plymouth
So. Burlington, Vt.
Uuuuhhh, I would say that most racers use non-lock up converters.
[Re: fast68plymouth]
#2720870
12/02/19 12:57 PM
12/02/19 12:57 PM
Sammy
Wind Gap,Pa.
Uuuuhhh, I would say that most racers use non-lock up converters. Aren't the majority lock up converters? I thought 1/8th mile fast guys are using non lock up?
[Re: Sammy]
#2720873
12/02/19 01:06 PM
12/02/19 01:06 PM
fast68plymouth
So. Burlington, Vt.
A “proper” lock up converter has a clutch in it that’s activated by the transmission.
You need both a lock up converter, and the trans to go with it.
So...... no one running a regular 727 or 904 is using a lock up converter.
Unless there’s some current technology for those transmissions I’m not familiar with.
[Re: Sammy]
#2720874
12/02/19 01:08 PM
12/02/19 01:08 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Uuuuhhh, I would say that most racers use non-lock up converters. Aren't the majority lock up converters? I thought 1/8th mile fast guys are using non lock up? No, like Dwayne said most everyone uses a non-lockup. But, the really fast turbo/Nitrous/outlaw types have recently started using them. Neal ChanceBillet Lockup Racing Converters
Starting at -$7,300.00
The latest innovation from Neal Chance Racing Converters is the Full Billet Internal Lock Up Racing Converter. This unique new converter was a top secret joint project between NCRC and Rossler Racing Transmissions, but the cat is out of the bag now! This converter has captured and HELD ALL the Turbo World Records and ALL the Pro Nitrous Records in PDRA!!!
It works either with a TH400 Based Transmission such as the 3 speed, 2 speed TurboGlide, Ty-Drive or Bruno Drive. The Lockup Converter offers far more durability than a “Dry” clutch, with the ability to last an entire season in a 3.70 Nitrous car with no wear!
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2720875
12/02/19 01:14 PM
12/02/19 01:14 PM
fast68plymouth
So. Burlington, Vt.
Perhaps the OP is confusing “non-lock up” with “spragless”??
[Re: topside]
#2720908
12/02/19 03:28 PM
12/02/19 03:28 PM
Posts: 740 WA
JD Dart
WA
You need a power adder in order to gain any ET benefits my little 499 wouldn't recover from a 700 rpm drop from the highest load going down the track from increased wind friction for example I shifit into lockup at 7250 rpm drops to 6550 that puts me at 7.28 seconds into a 8.87 run now the motor only has 1.59 seconds to recover some and increase mph my thought it would just stall there and maybe get up to 6600-6650 mph would be down from a non lockup run.
best so far 8.53 @ 158.59 MPH 60'1.240
#2720916
12/02/19 03:40 PM
12/02/19 03:40 PM
Posts: 1,765 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
...So...... no one running a regular 727 or 904 is using a lock up converter. Unless there’s some current technology for those transmissions I’m not familiar with. ugh??? Both transmissions got the factory lock-up functionality around '78 I think (give or take a year?). As applicable to drag racing I would agree that most probably run non lock-up setups. However, I for one have a lock-up 518 here and would consider running a high-stall lock-up converter in it. I haven't gotten anywhere near actually being able to prep the transmission and make the appropriate changes to use that setup in my coupe, but one of these days I would consider doing so.
[Re: Diplomat360]
#2720918
12/02/19 03:44 PM
12/02/19 03:44 PM
fast68plymouth
So. Burlington, Vt.
I thought the transmissions got a different number designation when they went to the lock-up. Like a 904 was a 999, or something like that.
In any case, you need a transmission that has the capability to operate the lock up clutch for it to work.
Edit: I see there are in fact lock up 727’s and 904’s....... which would be used with specific clutch equipped converters for that feature to be operational.
Your typical TA 10”, Dynamic 9.5”, 8” ATI Treemaster, etc....... are non-lock up.
[Re: Sammy]
#2720922
12/02/19 03:49 PM
12/02/19 03:49 PM
Posts: 4,210 New York
polyspheric
New York
I have a lock-up converter in my A340E OD transmission. The box will take 800 hp, the converter clutch will take 350.
Boffin Emeritus
[Re: polyspheric]
#2720964
12/02/19 06:00 PM
12/02/19 06:00 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
All the torque multiplication goes away once you lock up the converter so when used in a race application you better be bringing plenty of torque with you...as stated earlier a "Power" adder motor. Not too many (if any) Naturally aspirated motors will pick up with one. 2spd w/lockup converter
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Diplomat360]
#2720972
12/02/19 06:24 PM
12/02/19 06:24 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
ugh???
Somewhere in the back of the shed I have a big-block 727 lockup trans and converter I decided to squirrel away at one time. I believe it's a '78. 727s and 518s could be had either way but 904 variants were all lockup from some point on.
[Re: W.I.N. Racing]
#2720983
12/02/19 07:14 PM
12/02/19 07:14 PM
polyspheric
New York
It's already gone when the car rolls out.
Boffin Emeritus
[Re: polyspheric]
#2720985
12/02/19 07:23 PM
12/02/19 07:23 PM
Posts: 3,092 Michigan
A727Tflite
It's already gone when the car rolls out. It doesn’t immediately “disappear” after you leave the starting line.
