BRACKET COMBOS/BRACKET TIMES #2720024
11/28/19 12:00 PM
11/28/19 12:00 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Spent some time racing a slant 6. Very interesting viewpoint being chased.What's a best time/best combo for bracket racing?
Re: BRACKET COMBOS/BRACKET TIMES [Re: A/MP] #2720025
11/28/19 12:06 PM
11/28/19 12:06 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Mine is probably one of the dumbest. Nose heavy, around 900hp,10.5" tire, footbrake. That being said its a lot of fun. I'm almost always chasing. Dial around 5.8x/9.1x,or 9.25 index. 18 finals in just over 100 events.
Doug
Re: BRACKET COMBOS/BRACKET TIMES [Re: dvw] #2720055
11/28/19 01:33 PM
11/28/19 01:33 PM
gregsdart Offline
gregsdart  Offline
Best situation i ever had; stroked 440 on alky, hydraulic cam, over 50 percent on the back, 14x32 &cage ran 10.20s
Re: BRACKET COMBOS/BRACKET TIMES [Re: A/MP] #2720067
11/28/19 02:11 PM
11/28/19 02:11 PM
For what purpose? Going slow or fast?
BTW, the driver does have some input on the cars results work whistling stirthepot grin
AKA aside I think I do better when I get to leave first, I've never bracket raced a car slower than mid 12. seconds in the 1/4 mile, my current S/P car run high 8s at 15.0 MPH in the 1/4, mile 5.50 at 120 MPH in the 1/8 mile realcrazy shruggy
Re: BRACKET COMBOS/BRACKET TIMES [Re: Cab_Burge] #2720091
11/28/19 03:22 PM
11/28/19 03:22 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
15.30's for the V/SA /6 and 8.90-9.20's with an Altered and a MP car back in the 70's. I was giving thought to a big torque 360 or a lower revving 440 to have plenty of TQ to power my way thru just in case of a slight glitch. With a lower ET, somewhere in the 12s' and plenty of TQ, there should be some wiggle when playing the stripe with faster cars. Yes/NO?
Re: BRACKET COMBOS/BRACKET TIMES [Re: A/MP] #2720113
11/28/19 04:46 PM
11/28/19 04:46 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
a mate I race with has this idea . Runs around 12 flat but @ 115/117mph or so . This is in a LS3 chev powered Holden ute . His idea is get a lot of tree and not be overrun in the top end . Except for guys like me @ near 130 , but it will be close to stripe where I pick him up , so less room for me to back up . He also races a high 11s VW , bit quicker but a few less mph . He cant lift with the VW
I have to say it is a plan than can work
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: BRACKET COMBOS/BRACKET TIMES [Re: tex013] #2720117
11/28/19 05:15 PM
11/28/19 05:15 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have raced slow cars most of my career. Leaving first gives the other guy lots of time to lose the tree, but if I hang a red it's moot.
My Slant now runs low 13s most of the time, but I moved into Pro so I'm still being chased.
My experience is if I cut a good light and run my number it doesn't matter if I'm first or last.
I do know that when I was running a 19 second car in Gambler's races fast guys hated me.
Re: BRACKET COMBOS/BRACKET TIMES [Re: slantzilla] #2720130
11/28/19 06:54 PM
11/28/19 06:54 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My saying is Small Blocks rule the world.......
I say that because in most bracket classes, the small block comes out on top....Why, simple....Lower HP, less breakage, less tire slippage on marginal track, gives you more seat time.
A hydraulic cammed small block with a decent slick and good suspension is really tough to beat...Especially if they are allowed a trans brake and two step.
Re: BRACKET COMBOS/BRACKET TIMES [Re: A/MP] #2720185
11/29/19 12:09 AM
11/29/19 12:09 AM
I know good bracket racers that hold a lot more than I do and I know other guys the will dial what it ran the last run or even add,001 to ,002 faster realcrazy I like racing all of them, I do hold from .01 to .03 usually, I can always loose ET, but I can't gain any ET normally also shruggy work
You have to drive both ends of the track better than your opponent to win in bracket racing, correct work grin
Re: BRACKET COMBOS/BRACKET TIMES [Re: Cab_Burge] #2720221
11/29/19 11:05 AM
11/29/19 11:05 AM
my own world
theraif Offline
theraif  Offline
my own world
our dart was set up to fright train on the top end , fooled a few people couple of the best were 11 sec cars running the same mph,,,,,2.00-2.10 60ft 8.60 in the 1/8th 13.30s@107-110 mph
Re: BRACKET COMBOS/BRACKET TIMES [Re: Cab_Burge] #2720224
11/29/19 11:20 AM
11/29/19 11:20 AM
UK
rb446 Offline
rb446  Offline
UK
Well were going to step things up next year form going 12.6's@105+ with a near stock 440 to lowish 10's@130+, with a mild 588. I reckon that'll give us better parity with the 60's and mph with the other cars that run in our brkt, most of who are in the high 9's so the battle will be more@the top end and not lost@the start especially if our RT is a bit weak against our op. Chasing someone down near the line to take the stripe invariably ends up with a breakout unless you pass them early and that shouldn't happen to us too often except for 1 car that runs 9.0's@150 which is the cut off ET for the class, but he breaks out a lot as it is with 8.90's. There can be 1>2tnths change in conditions@SPR from day to late afternoons/evenings, other racers don't follow things like that too much so we got a good chance in going rounds if we are on the ball.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: BRACKET COMBOS/BRACKET TIMES [Re: rb446] #2720380
11/30/19 01:24 AM
11/30/19 01:24 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
My Satellite uses a simple flat tappet, pump gas 400/451. It typically runs in the high 11.20’s or low 30’s at 118 and is still a perfectly suitable weekend street hot rod. I footbrake it, as it does not have a transbrake. It runs an 8-3/4 with 4.10’s on a spool.
I’m the slower car roughly 60% - 70% of the time at my local track in Pro E/T.
Re: BRACKET COMBOS/BRACKET TIMES [Re: StealthWedge67] #2720391
11/30/19 08:16 AM
11/30/19 08:16 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I think you can bracket race anything. You got to cut a light, know your vehicle and run your own race. Knowing your car comes from experience and not changing the combo in an effort to go quicker (like I do smirk ) If you're serious about it keeping data is key. The best bracket racers run the same combo year in year out and leaving last gives you the first foul advantage. twocents
Re: BRACKET COMBOS/BRACKET TIMES [Re: Tig] #2720803
12/01/19 10:58 PM
12/01/19 10:58 PM
Puyallup, WA
Puyallup, WA
No more 1st foul advantage at any track using True-Start. You certainly can Bracket just about anything that runs well, My opinion is that there will be an advantage to being the faster car. A) It’s much easier to judge the race when it’s all in front of you; and B) the faster car has more options once the cars are even at the big end. With that said, the biggest advantage will always lie with the guy that left on time and is on his number.
Re: BRACKET COMBOS/BRACKET TIMES [Re: Tig] #2720815
12/02/19 12:09 AM
12/02/19 12:09 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I agree wholeheartedly here with this guy. The problem I have is sticking with the same car, always want to go faster. Not sure if Tru-Start will catch on, but I don’t mind it. Been doing the Spring Fling thing for a few years and have seen Tru-start do some amazing things. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: BRACKET COMBOS/BRACKET TIMES [Re: StealthWedge67] #2720823
12/02/19 03:47 AM
12/02/19 03:47 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Originally Posted by StealthWedge67
No more 1st foul advantage at any track using True-Start. .
Ahh forgot about that but it's not something that's been adopted in the UK (yet) up
Re: BRACKET COMBOS/BRACKET TIMES [Re: Tig] #2720824
12/02/19 06:29 AM
12/02/19 06:29 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
driver is as good as the car,you need to cut a light and do it every pass,foot brake or box,best car in the world is nothing without a driver,seems like all that wins in my area is chevy owners,fast or slow,i dont want to bracket race anymore,for being known as a duck
