Any turbo small block on this forum? #2720592
12/01/19 10:35 AM
12/01/19 10:35 AM
east coast
Otherlane Offline OP
east coast
I'm building a little duster street car. I haven't decided on turbo or NOS. I have both power adder but leaning towards the turbo. Does anyone have a turbo small block duster that can share pics of the engine so i can see what i have to do? This will be a blow thru set up. I'm looking to see the exhaust and plumbing set. Thanks
Re: Any turbo small block on this forum? [Re: Otherlane] #2720600
12/01/19 11:19 AM
12/01/19 11:19 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Paging Dizuster...
Kevin
Re: Any turbo small block on this forum? [Re: Twostick] #2720631
12/01/19 01:38 PM
12/01/19 01:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dizuster is in China for 2 weeks for work. With no power steering you can turn magnum truck manifolds around backward. With PS it gets a little tougher. as one manifold gets an adapter and is turned upside down. This is a B body but we've fitted them in A body as well.
Doug
Re: Any turbo small block on this forum? [Re: dvw] #2720676
12/01/19 04:11 PM
12/01/19 04:11 PM
east coast
east coast
Do you have pics of the right side?..did you buy the exhaust between the manifold? Why no headers?
Re: Any turbo small block on this forum? [Re: Otherlane] #2720751
12/01/19 07:21 PM
12/01/19 07:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Really no need. These aren't even the big outlet manifolds. I believe they're1 7/8". Its been 9.55@14, 3750lbs. There's way more left in it. However the factory cast crank might not like it.
ZDSC_9623 _912_.JPG2011-07-24_10-22-42_160.jpg2011-07-24_10-22-50_140.jpg2011-07-24_10-25-15_281.jpg
Re: Any turbo small block on this forum? [Re: dvw] #2720757
12/01/19 07:45 PM
12/01/19 07:45 PM
east coast
east coast
I am planning to do a 408 with a steel crank and h beam rods....but looks it takes a lot to do the plumbing. I don’t want to get involved than halfway through decide on going nos
Re: Any turbo small block on this forum? [Re: Otherlane] #2722792
12/09/19 06:17 PM
12/09/19 06:17 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
73 Duster here. I mounted mine further to the passenger side than Dizuster and have a smaller framed 78/75 T4 turbo than his S400. Flipped magnum manifolds, relocated alternator to driver side, and a remote oil filter to sneak the downpipe through. No cutting of anything. The junction off the passenger manifold to the turbo inlet merge probably isnt ideal, but it'll work for my goals. Microsquirt with LS throttle body/coils/sensors and a crank position sensor from SD Concepts on the board here.
Re: Any turbo small block on this forum? [Re: j.mcconnell] #2722842
12/09/19 10:48 PM
12/09/19 10:48 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Where is Jody Babcock? He has one of the cleanest SBM single turbo set ups out there!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Any turbo small block on this forum? [Re: j.mcconnell] #2723933
12/14/19 10:01 AM
12/14/19 10:01 AM
east coast
east coast
i like your set up...so using manifolds are ok vs headers? I'm looking at a 76mm turbo and blow Th
through carb. I just don't want to get to involved then change my mind and throw on the induction solutions plate that i already have.
Re: Any turbo small block on this forum? [Re: Otherlane] #2724205
12/15/19 02:55 PM
12/15/19 02:55 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Here is a early A-body with a 360 I am currently doing. This is my first turbo piping build so I'm learning as we go. I can tell you its tight! I think twins would almost be easier and dual waste-gates would probably help as well...[Linked Image]
Passenger side header modified...
[img]https://i.imgur.com/9aUYS5d.jpg[/img
][Linked Image]
Re: Any turbo small block on this forum? [Re: Forest] #2724742
12/17/19 10:59 AM
12/17/19 10:59 AM
east coast
east coast
][Linked Image]
beautiful!!
Re: Any turbo small block on this forum? [Re: Otherlane] #2725152
12/18/19 03:18 PM
12/18/19 03:18 PM
east coast
east coast
What size converter are you guys running??
Re: Any turbo small block on this forum? [Re: Otherlane] #2725610
12/20/19 12:30 PM
12/20/19 12:30 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I finished the car and thought anyone looking at this post would like to see the final product.
Turbo oil drain into the fuel pump block off rather than pulling the pan to install a bulkhead...
Re: Any turbo small block on this forum? [Re: Otherlane] #2725793
12/21/19 09:50 AM
12/21/19 09:50 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
It's not so much about the size, as it is who's converter it is/what version.
I have tried many converters. The problem with a turbo car is getting it to stall high enough on motor alone to light the turbo, but tight enough that once the boost comes on it doesn't stall too high.
For example... I had had many iterations of the lower cost 9.5" PTC. It worked extremely well at moderate HP levels (say below 650~700hp or so). But when I really started turning up the boost/power, it just wouldn't work. The last version of that converter Kenny (from PTC) and I tried, would stall 2200rpm on motor, and 5600rpm on full boost. The 2200rpm made it EXTREMELY slow to spool, and the 5600rpm was just WAY to high for this motor.
After that I moved to another 9.5" Nissan Core PTC converter. This one now stalls about 3400rpm on motor only (which makes it easy to build boost and bracket race), and stalls about 5200rpm on full boost (which is a lot better for this motor). It also cost 3x as much though!!!!
