Rocker shafts #2720555
12/01/19 02:58 AM
12/01/19 02:58 AM
Long Beach, CA
Mike Swann Offline OP
Long Beach, CA
A question about rockershafts; I am running some old shafts that I bent up pretty bad racing years ago, on the street. I would like to get some straight shafts on the car. I know T&D and Comp have nice medium alloy steel shafts. Is there a less expensive solution that will take 450 lbs on the nose and 6500 rpm?
Thanks,
Mike
8.30's @3400 lbs
Re: Rocker shafts [Re: Mike Swann] #2720556
12/01/19 03:16 AM
12/01/19 03:16 AM
I may have a set of the Speed Pro H.D. extra thick shafts in stock, the bad things is they are not banana grooved and they don't work with needle bearing rockers. I learn that the hard way about the needle bearing rockers on those shafts whiney I now use the shafts that 440 Source sells for their needle bearing rockers for springs under 700 Lbs. pressure up scope
Re: Rocker shafts [Re: Mike Swann] #2720825
12/02/19 07:17 AM
12/02/19 07:17 AM
Minn
SportF Offline
SportF  Offline
Minn
Give Stanke Motorsports a call http://www.stankemotorsports.com/mopar/index.htm He doesn't update his website, but started making them last summer. He has some of the nicest shafts out there and the best price in my opinion. He has been making shafts for racers for a long time for hemi's, late and early. 651 481 0147
Re: Rocker shafts [Re: Mike Swann] #2720826
12/02/19 07:21 AM
12/02/19 07:21 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Needle bearings? Harland Sharp
No needle bearings? Hughes
Re: Rocker shafts [Re: SportF] #2720837
12/02/19 09:37 AM
12/02/19 09:37 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Here are the Stanke shafts: https://www.ebay.com/itm/361-440-MOPAR-ROCKER-ARM-SHAFTS-1-PAIR-2/264431126226
Melonized and grooved! up
$130 (not sure if you could get them cheaper directly from Stanke)
Re: Rocker shafts [Re: BradH] #2721631
12/05/19 11:18 AM
12/05/19 11:18 AM
Long Beach, CA
Long Beach, CA
They're Indy rockers , bored and honed aluminum
8.30's @3400 lbs
Re: Rocker shafts [Re: SportF] #2721661
12/05/19 12:53 PM
12/05/19 12:53 PM
Long Beach, CA
Long Beach, CA
I went with the Stanke product. Thanks for all the help and Merry Christmas!
8.30's @3400 lbs
