AAR Spoiler Mounting Question #272050
03/30/09 09:55 PM
03/30/09 09:55 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
Are there gaskets used between the spoiler and trunk lid? If so who sells them?
Al & Sheila
Re: AAR Spoiler Mounting Question [Re: 3twos] #272051
03/31/09 08:28 AM
03/31/09 08:28 AM
SC
Cooda Offline
Cooda  Offline
SC
Good question, what did the factory use to seal the holes in the trunk lid, where the mounting studs come through?
Re: AAR Spoiler Mounting Question [Re: 3twos] #272052
03/31/09 01:34 PM
03/31/09 01:34 PM
uk
TiMopar Offline
TiMopar  Offline
uk
Judging by how my original AAR trunklid rusted I would say there was no gasket or sealer!
Re: AAR Spoiler Mounting Question [Re: TiMopar] #272053
03/31/09 02:18 PM
03/31/09 02:18 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
I have had a different problem with mine.I used laquer organisol paint on my spoiler and after a while the paint bubbled where the spoiler comes in contact with the paint. I think something leached out of the laquer paint in the hot sunshine and caused the problem. I have not seen any type of gaskets for sale and I assume they never used them. I will probably silicone the holes to keep water out.
Al & Sheila
Re: AAR Spoiler Mounting Question [Re: 3twos] #272054
03/31/09 05:45 PM
03/31/09 05:45 PM
middle of the country
aar1 Offline
aar1  Offline
I went to the hardware store and bought some big flat rubber washers. Helps to seal the hole plus holds the spoiler up off the decklid just a hair.
Re: AAR Spoiler Mounting Question [Re: aar1] #272055
04/12/09 02:11 PM
04/12/09 02:11 PM
Arizona
jsully Offline
jsully  Offline
Arizona
Do you have any photos of the mounts on the spoiler and the location of the holes in the trunk lid?
I bought the mount kit and have not figured exactly how this attaches.
Happy Easter
Re: AAR Spoiler Mounting Question [Re: aar1] #272056
04/12/09 02:44 PM
04/12/09 02:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Silicone only promotes rust by traping/assorbing water after some time, if you must use a sealer use seam sealer or a ureathane based sealer, or butuly rubber based gasketing mat'l
Re: AAR Spoiler Mounting Question [Re: jsully] #272057
04/12/09 06:27 PM
04/12/09 06:27 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
Happy Easter
I cut a few pieces of gasket paper and and put them on the four studs and also three pieces where the spoiler touches the trunk lid. I also did not use the four screws that go up through the trunk lid on the ends as there is a gap between the spoiler and lid and I did not want to crack the spoiler.
Here are some pics
Al & Sheila
Re: AAR Spoiler Mounting Question [Re: 3twos] #272058
04/12/09 06:28 PM
04/12/09 06:28 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
bottom
Al & Sheila
Re: AAR Spoiler Mounting Question [Re: 3twos] #272059
04/12/09 06:28 PM
04/12/09 06:28 PM
Minnesota
3twos Offline OP
3twos  Offline OP
Minnesota
top
Al & Sheila
Re: AAR Spoiler Mounting Question [Re: 3twos] #272060
04/13/09 12:22 PM
04/13/09 12:22 PM
Arizona
jsully Offline
jsully  Offline
Arizona
These pictures help alot. Thank you.
Honestly I was headed in the wrong direction to mount mine.
