Re: Open chamber aluminum head [Re: Stanton] #2720930
12/02/19 04:16 PM
12/02/19 04:16 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Originally Posted by Stanton
Cometics are MLS and require a specific finish on the block and heads. Mine does not have that finish and everyone I've talked to (Cometic and engine builders) say they won't work properly.
I have been known to 'lap' by hand bad surfaces with a good long hand file for ...20 some years and never had an issue. If you choose to run cometics.
Re: Open chamber aluminum head [Re: HardcoreB] #2720974
12/02/19 06:36 PM
12/02/19 06:36 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Nah, ain't going that route.
Re: Open chamber aluminum head [Re: fast68plymouth] #2720981
12/02/19 07:00 PM
12/02/19 07:00 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
How are the SCE Titans for water and oil leaks? work
Re: Open chamber aluminum head [Re: DrCharles] #2720998
12/02/19 08:13 PM
12/02/19 08:13 PM
I've use the ICE Titan, the ones with the built in O rings, with great success on blocks with no receiver grooves up They where all thicker than .042 though work
I did use 2 or 3 coats of Copper Coat as a sealer also up
Re: Open chamber aluminum head [Re: Cab_Burge] #2721001
12/02/19 08:28 PM
12/02/19 08:28 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
yep, they have eight ICS ones (at the bottom of the page) and the thinnest is .043. They aren't giving them away, either!
https://www.scegaskets.com/product-category/chrysler/big-block-chrysler/chrysler-wedge-head-gaskets/
Re: Open chamber aluminum head [Re: DrCharles] #2721010
12/02/19 09:12 PM
12/02/19 09:12 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I use Permatex copper coat on mine, no leaks!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
