Re: Open chamber aluminum head
[Re: Stanton]
#2720930
12/02/19 04:16 PM
12/02/19 04:16 PM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Cometics are MLS and require a specific finish on the block and heads. Mine does not have that finish and everyone I've talked to (Cometic and engine builders) say they won't work properly. I have been known to 'lap' by hand bad surfaces with a good long hand file for ...20 some years and never had an issue. If you choose to run cometics.
[Re: HardcoreB]
#2720974
12/02/19 06:36 PM
12/02/19 06:36 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Cometics are MLS and require a specific finish on the block and heads. Mine does not have that finish and everyone I've talked to (Cometic and engine builders) say they won't work properly. I have been known to 'lap' by hand bad surfaces with a good long hand file for ...20 some years and never had an issue. If you choose to run cometics. Nah, ain't going that route.
[Re: DrCharles]
#2720998
12/02/19 08:13 PM
12/02/19 08:13 PM
Posts: 43,311 Bend,OR USA
Cab_Burge
I've use the ICE Titan, the ones with the built in O rings, with great success on blocks with no receiver grooves ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) They where all thicker than .042 though I did use 2 or 3 coats of Copper Coat as a sealer also
[Re: DrCharles]
#2721010
12/02/19 09:12 PM
12/02/19 09:12 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I use Permatex copper coat on mine, no leaks!
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
