Re: BRACKET COMBOS/BRACKET TIMES
[Re: A/MP]
#2720025
11/28/19 12:06 PM
11/28/19 12:06 PM
Posts: 9,847 MI, usa
dvw
MI, usa
Mine is probably one of the dumbest. Nose heavy, around 900hp,10.5" tire, footbrake. That being said its a lot of fun. I'm almost always chasing. Dial around 5.8x/9.1x,or 9.25 index. 18 finals in just over 100 events. Doug
[Re: A/MP]
#2720113
11/28/19 04:46 PM
11/28/19 04:46 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
a mate I race with has this idea . Runs around 12 flat but @ 115/117mph or so . This is in a LS3 chev powered Holden ute . His idea is get a lot of tree and not be overrun in the top end . Except for guys like me @ near 130 , but it will be close to stripe where I pick him up , so less room for me to back up . He also races a high 11s VW , bit quicker but a few less mph . He cant lift with the VW I have to say it is a plan than can work
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2720117
11/28/19 05:15 PM
11/28/19 05:15 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
I have raced slow cars most of my career. Leaving first gives the other guy lots of time to lose the tree, but if I hang a red it's moot.
My Slant now runs low 13s most of the time, but I moved into Pro so I'm still being chased.
My experience is if I cut a good light and run my number it doesn't matter if I'm first or last.
I do know that when I was running a 19 second car in Gambler's races fast guys hated me.
[Re: Cab_Burge]
#2720224
11/29/19 11:20 AM
11/29/19 11:20 AM
Posts: 570 UK
rb446
UK
Well were going to step things up next year form going 12.6's@105+ with a near stock 440 to lowish 10's@130+, with a mild 588. I reckon that'll give us better parity with the 60's and mph with the other cars that run in our brkt, most of who are in the high 9's so the battle will be more@the top end and not lost@the start especially if our RT is a bit weak against our op. Chasing someone down near the line to take the stripe invariably ends up with a breakout unless you pass them early and that shouldn't happen to us too often except for 1 car that runs 9.0's@150 which is the cut off ET for the class, but he breaks out a lot as it is with 8.90's. There can be 1>2tnths change in conditions@SPR from day to late afternoons/evenings, other racers don't follow things like that too much so we got a good chance in going rounds if we are on the ball.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2720380
11/30/19 01:24 AM
11/30/19 01:24 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My Satellite uses a simple flat tappet, pump gas 400/451. It typically runs in the high 11.20’s or low 30’s at 118 and is still a perfectly suitable weekend street hot rod. I footbrake it, as it does not have a transbrake. It runs an 8-3/4 with 4.10’s on a spool.
I’m the slower car roughly 60% - 70% of the time at my local track in Pro E/T.
[Re: StealthWedge67]
#2720391
11/30/19 08:16 AM
11/30/19 08:16 AM
Posts: 2,924 A shed in England
Tig
A shed in England
I think you can bracket race anything. You got to cut a light, know your vehicle and run your own race. Knowing your car comes from experience and not changing the combo in an effort to go quicker (like I do ) If you're serious about it keeping data is key. The best bracket racers run the same combo year in year out and leaving last gives you the first foul advantage.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2720803
12/01/19 10:58 PM
12/01/19 10:58 PM
StealthWedge67
Puyallup, WA
I think you can bracket race anything. You got to cut a light, know your vehicle and run your own race. Knowing your car comes from experience and not changing the combo in an effort to go quicker (like I do ) If you're serious about it keeping data is key. The best bracket racers run the same combo year in year out and leaving last gives you the first foul advantage. No more 1st foul advantage at any track using True-Start. You certainly can Bracket just about anything that runs well, My opinion is that there will be an advantage to being the faster car. A) It’s much easier to judge the race when it’s all in front of you; and B) the faster car has more options once the cars are even at the big end. With that said, the biggest advantage will always lie with the guy that left on time and is on his number.
[Re: Tig]
#2720815
12/02/19 12:09 AM
12/02/19 12:09 AM
Posts: 422 montana
BANDIT
montana
I agree wholeheartedly here with this guy. The problem I have is sticking with the same car, always want to go faster. Not sure if Tru-Start will catch on, but I don’t mind it. Been doing the Spring Fling thing for a few years and have seen Tru-start do some amazing things. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
#2720823
12/02/19 03:47 AM
12/02/19 03:47 AM
Tig
A shed in England
No more 1st foul advantage at any track using True-Start. . Ahh forgot about that but it's not something that's been adopted in the UK (yet)
