Re: Killed it [Re: tubtar] #2719823
11/27/19 05:53 PM
11/27/19 05:53 PM
oregon
greendart408 Offline
oregon
Sorry Shiloh, was it a ccw crank or non? Just curious. My Bryant in my f2 w8 deal is non ccw and seems to be a wet noodle in there somewhat.
Re: Killed it [Re: DrCharles] #2719834
11/27/19 06:13 PM
11/27/19 06:13 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Oh, wow. Sorry to see this. I understand. I had one come apart on the dyno and destroy nearly everything, but not as bad as yours. I had a bit over $10,000 in it. I'm sure you had much more invested. Sorry .
Re: Killed it [Re: mopar dave] #2719835
11/27/19 06:33 PM
11/27/19 06:33 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That engine wasn't mine (fortunately!), I just found the picture online and used it for comparison purposes wink
But if OP busted a crank, it's quite possible that the rods also beat up on the block too...
Re: Killed it [Re: DrCharles] #2719836
11/27/19 06:34 PM
11/27/19 06:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by DrCharles
Sorry you broke your crank... hope the block is still in usable (or repairable) condition! scope
Could have been worse though... whistling
Holy cow, what the heck happened here .
Ive never seen a block that damaged
Re: Killed it [Re: WHITEDART] #2719860
11/27/19 08:46 PM
11/27/19 08:46 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Awesome shot!
Re: Killed it [Re: pittsburghracer] #2719925
11/28/19 01:29 AM
11/28/19 01:29 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Originally Posted by pittsburghracer
Sorry to hear you had some bad luck buddy. I love following your track success stories. How’s the block look.
. Other than all the main Are extremely use the block seems OK
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Killed it [Re: greendart408] #2719926
11/28/19 01:31 AM
11/28/19 01:31 AM
bean town ....Ca
W
W
bean town ....Ca
. No it was not center counterweighted.. Once I went to a dry sump the bearings always looked good...
Re: Killed it [Re: BobR] #2719927
11/28/19 01:37 AM
11/28/19 01:37 AM
bean town ....Ca
W
W
bean town ....Ca
Originally Posted by BobR
What kind of crank is that?
. Bob it Was a King crank . And Forged in America... Actually discontinued now.. but we cycled it hard for close to 4 years.. I guess now I know how long one will last..
Re: Killed it [Re: J_BODY] #2719928
11/28/19 01:39 AM
11/28/19 01:39 AM
bean town ....Ca
W
W
bean town ....Ca
Between here, other Mopar forums, FB etc.... I’m not certain that I saw an early Ritter block live or in some cases even run at the level Shiloh’s did..... and we’ll use the term “live” loosely. They went great lengths to “make it” work. I’m thinking it will live out it’s days as a coffee table, mail box holder, or a lawn decoration of some sorts.
. No one can ever say we gave up that's for sure...
Re: Killed it [Re: WHITEDART] #2719942
11/28/19 04:10 AM
11/28/19 04:10 AM
gregsdart Offline
gregsdart  Offline
Sorry to. See the carnage, but good to see the new build underway. Serious stuff you have there!
Re: Killed it [Re: WHITEDART] #2720064
11/28/19 02:02 PM
11/28/19 02:02 PM
I'm going to assume you and the car didn't get hurt, which is the only positive thing I can take form that motors death wave
Do any of the new motor parts come from up north?
How soon will it be in the car? work
Re: Killed it [Re: Cab_Burge] #2720081
11/28/19 02:38 PM
11/28/19 02:38 PM
bean town ....Ca
W
W
bean town ....Ca
. Yes cab we are going to use the block and thanks again for the lead.. Yup everyone was safe and nothing exited the motor
Re: Killed it [Re: WHITEDART] #2720150
11/28/19 08:06 PM
11/28/19 08:06 PM
Nevada
merpar Offline
merpar  Offline
Nevada
Dang Shiloh, that's a tough pill to swallow. Been there done that myself. But at my age it has taken me 8 yrs to put things back together. Am sure you are getting lots of advice. So thought I would put a penny's worth in. Can't afford 2 cents. Just looking at your pics I see a couple things I would address. With the rpm you're turning I would look at rotating assembly weight. Maybe BM aluminum rods. I see a serious problem with the pistons. Heavy scuffing up by the ring grooves= bad skirt profile. Just trying to suggest changes I would look into. Not trying to be a know it all, ain't the brightest light in the room. But I've learned from my mistakes. Oh if you don't mind one more thing I would look into would be a center weighted crank. That's my pennies worth. Best of luck to you in your future build.
Re: Killed it [Re: merpar] #2720154
11/28/19 08:58 PM
11/28/19 08:58 PM
bean town ....Ca
W
W
bean town ....Ca
. I value everyone input that's what has helped me get to where we are... It seems to be a continuous progression of It seems to be a continuous progression of ET and knowledge all the time and knowledge all the time
Re: Killed it [Re: WHITEDART] #2720182
11/29/19 12:01 AM
11/29/19 12:01 AM
It good to see them going to use instead of gathering dust up
Re: Killed it [Re: WHITEDART] #2720337
11/29/19 09:06 PM
11/29/19 09:06 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
R.I.P. You done a good job with that hunk of steel !!!!! Raised a lot of eyebrows..
Hat Tipped .... thumbs beer
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Killed it [Re: WHITEDART] #2720412
11/30/19 10:57 AM
11/30/19 10:57 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
Originally Posted by WHITEDART
Lost some oil pressure at the West Coast hot Rod Race. We were running ultra street AKA limited 235.. This is an image of the last pass it made
Sorry to hear the engine give out, that is one mean Small block, and lasted long .
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Killed it [Re: Ray408G3Hemi] #2720946
12/02/19 04:57 PM
12/02/19 04:57 PM
an8sec70cuda Offline
Hate to see this, but good you've almost got a replacement ready!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Killed it [Re: an8sec70cuda] #2721038
12/02/19 11:27 PM
12/02/19 11:27 PM
bean town ....Ca
W
W
bean town ....Ca
No one can say we didn't race it... We ran it through its paces often.... Hopefully the replacement performs as well as this one did
Re: Killed it [Re: WHITEDART] #2722101
12/06/19 07:01 PM
12/06/19 07:01 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
On the bright side it looks like the car left straight!
Sorry about the motor :-(
