What X heads are these? #2719293
11/25/19 08:21 PM
11/25/19 08:21 PM
restos just aren't my thing
gtsuperbee Offline OP
I bought a small block engine and at first I thought it had X heads on it. Now, after looking at the couple pics I took, the center exhaust port isn't configured like I normally see. So what did I get? smile If nothing else, I am going to pick it up next weekend, and I will be able to pull a valve cover and get a number
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: What X heads are these? [Re: gtsuperbee] #2719302
11/25/19 08:49 PM
11/25/19 08:49 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Not much to go by in those pics, and I haven’t too much in the way of the “-3” engines....... but I’m gonna guess that it’s something along those lines....... as in HD or MH.
Re: What X heads are these? [Re: gtsuperbee] #2719303
11/25/19 08:52 PM
11/25/19 08:52 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Maybe a replacement Indy LA-X or MA-X head?
Dwayne are you referencing a truck or motorhome cylinder head?
Re: What X heads are these? [Re: RTSrunner] #2719307
11/25/19 09:00 PM
11/25/19 09:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
I am........ or some sort of industrial head.
Like I said, I know there’s quite a few different ones, and I’ve hardly seen any of them.
The Indy heads have magnum looking ex ports(all also have dual bolt pattern I believe), along with the ends of the heads.
Re: What X heads are these? [Re: RTSrunner] #2719308
11/25/19 09:01 PM
11/25/19 09:01 PM
The x head ports I know look like this
Re: What X heads are these? [Re: gtsuperbee] #2719314
11/25/19 09:15 PM
11/25/19 09:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
Only pic I could find:
318-3
What the OP bought could easily be a Chrysler Marine engine too.
Those things used lots of unique parts.
Re: What X heads are these? [Re: fast68plymouth] #2719330
11/25/19 09:58 PM
11/25/19 09:58 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I guess we have to wait for casting numbers and dates to get more clues!
Re: What X heads are these? [Re: RTSrunner] #2719359
11/26/19 01:30 AM
11/26/19 01:30 AM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
Those heads don't look like anything cast in the 60's or 70's
They would be something aftermarket or asomething Mopar Performance
Alan Jones
Re: What X heads are these? [Re: gtsuperbee] #2719365
11/26/19 02:00 AM
11/26/19 02:00 AM
AndyF Offline
AndyF  Offline
They look kind of like the Indy or RHS heads but not exactly. Here are some pictures from the Hughes website: http://www.hughesengines.com/TechArticles/8laxandmaxironsmallblockheads.php
Brian at IMM might know what they are. He knows most everything SB related. I've never seen anything like those heads before but everything I know about SB engines would fit on a matchbook cover.
Re: What X heads are these? [Re: AndyF] #2719401
11/26/19 10:10 AM
11/26/19 10:10 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I had a friend that showed me a set of heads like this. He told me they were early nascar heads. I guess the fore runner to the W-2 heads?
Getting old just means you were smarter than some and luckier than others.
Re: What X heads are these? [Re: dannysbee] #2720294
11/29/19 05:55 PM
11/29/19 05:55 PM
got it home. Here are the pics
Re: What X heads are these? [Re: gtsuperbee] #2720296
11/29/19 05:56 PM
11/29/19 05:56 PM
more
thumbnail_IMG_0339.jpgthumbnail_IMG_0343.jpgthumbnail_IMG_0348.jpgthumbnail_IMG_0340.jpg
Re: What X heads are these? [Re: gtsuperbee] #2720303
11/29/19 06:07 PM
11/29/19 06:07 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Interesting. The rocker pedestals are flat like a race W2 head so you are going to need blocks. That can be done to a standard set of heads if you want to be able to optimize the rocker geometry. But the intake push rod looks like it is in the standard place and not offset. Did you get the rocker setup with it?
Re: What X heads are these? [Re: gtsuperbee] #2720304
11/29/19 06:10 PM
11/29/19 06:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
Looks like a rare find on those heads.
Pretty cool!
The only reference I see has them listed as “340 Trans Am”.
They do require the offset intake rockers.
Perhaps some sort of DC T/A performance or replacement head.
Looks like someone has already done a little bowl work.
After looking at the pics a little more....... the stands look “too tall” compared to the valve length, especially considering there would need to be blocks added on top of the stands.
If they are in fact some sort of pre-W2 style head..... they may also be intended to be used with longer valves, like the original W2’s.
Re: What X heads are these? [Re: gtsuperbee] #2720306
11/29/19 06:13 PM
11/29/19 06:13 PM
AndyF Offline
AndyF  Offline
Is the casting number a 3462598? If so that is the Trans Am head. I've never seen the Trans Am head so I didn't know the exhaust ports looked like that. I would imagine they are worth some money if those are original Trans Am heads.
Re: What X heads are these? [Re: AndyF] #2720321
11/29/19 07:36 PM
11/29/19 07:36 PM
oregon
greendart408 Offline
oregon
Agree with fast, some sort of over the counter t/a replacement? Never seen them, it doesn’t look as offset as my race w2s sitting here. So I’m assuming it’s t/a offset rocker. The rocker stand uses blocks, like a long valve w2 tho. Interesting.....not original t/a chally or aar head
Re: What X heads are these? [Re: greendart408] #2720400
11/30/19 10:00 AM
11/30/19 10:00 AM
Locomotion Offline
Locomotion  Offline
To me, the intake pushrod holes DO look offset because they are not tucked against the intake port where the "bump" is. Coincidentally, the cast number "304" is right under the 305 cubic inch limit of the Trans Am series!
What are the dates and casting numbers on the block? "TA" ? Webbing round the main caps? Crank/stroke?
Direct Connection pre-W-2 is a good theory because the exhaust ports are raised, like a W-2, just squarish rather than D=port.
Anybody know anyone who worked with Bob Mullin? (Spelling?)
Re: What X heads are these? [Re: Locomotion] #2720403
11/30/19 10:15 AM
11/30/19 10:15 AM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
Yea, them are real t/a race heads, maybe a bit modified. Ive a pic of a pallot of them being prepped IIRC by Keith Black, but not fully sure if that was the guy or who did it but the heads share a good resemblance.
Id not be shocked if you were to find a short stroke crank if the builder went that far. Im surprised some of you older guys didnt comment on the head bolt brand.
GReat score, please post more pics.
STOP POTATO HATE!
Re: What X heads are these? [Re: Mr PotatoHead] #2720404
11/30/19 10:20 AM
11/30/19 10:20 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
MR.Gasket head bolts ......So you know that build goes back a few.
Re: What X heads are these? [Re: gtsuperbee] #2720419
11/30/19 11:43 AM
11/30/19 11:43 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Back in the 80's when Chrysler went broke the first time, they had to sell off a lot of performance stuff. Herb McCandless bought a bunch of it. I bought a stress relieved 340 block and a set of 340 heads, they looked a lot like those pictured. They had the pedestals milled off, 11/32 long stem valves. They had a tag on them noting a few hours dyno time. McCandless said they were developmental stuff Chrysler was doing. The casting numbers checked out to be a T/A head. I had a hard time back then getting the valve gear set up. I remember McCandless giving me Richard Petty's phone number and he told me what to buy to make it all work.
