1956 Pickup #2712385
11/03/19 12:36 PM
11/03/19 12:36 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
Hello Moparts, It's good to be back! 1st project is my Dads 56 pickup. It has drum brakes with a 440 motor installed! Not going to work here in Diego-Town. Has anyone done a disk brake conversion? I see there are a few kits on the market, anyone use any of them? Any and all suggestions will be apricated.
Thx Diego
Re: 1956 Pickup [Re: Diego_Ted] #2712498
11/03/19 06:02 PM
11/03/19 06:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Hope you are doing well Ted! I’ve even raced at Barona in your absence a couple times.
Jay
Re: 1956 Pickup [Re: J_BODY] #2712563
11/03/19 11:09 PM
11/03/19 11:09 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Ted,
When I did my 54, way back years ago I used a disc brake conversion from www.rustyhope.com. It worked pretty well, comes with the caliper brackets, the seat slip on ring, and a list of parts that make it work so you can source your own parts.
There are probably a lot of more modern kits out there, probably some that use current off the shelf parts.
The last several trucks I've just clipped with a Dakota frame, but that is a lot of extra work if all you need it a disc brake set up. Gene
Re: 1956 Pickup [Re: J_BODY] #2712650
11/04/19 12:18 PM
11/04/19 12:18 PM
Diego-Town, CA
Diego-Town, CA
J Bod, how you doing brother! Hope you are doing well. I am doing good, finally retired from the VA, glad to be back on the Moparts! Picked up the Race Trailer yesterday :-) Hoping to see the track sometime this year!
Diego
Re: 1956 Pickup [Re: poorboy] #2712653
11/04/19 12:22 PM
11/04/19 12:22 PM
Diego-Town, CA
Diego-Town, CA
Thanks PB, do you remember how complete and precise his instructions were? I can follow but I can't lead! LOL.
thx Ted
Re: 1956 Pickup [Re: Diego_Ted] #2712824
11/04/19 08:58 PM
11/04/19 08:58 PM
Freeport IL USA
Freeport IL USA
The Rusty Hope directions were pretty clear to me...
Basically, you remove all the original brake stuff off your axle. If I remember right (its been a very long time) there are two spindles Dodge used on the truck beam axle, one was a 3 bolt, and the other was a 4 bolt. He can help you get the right kit. You bolt the caliper brackets he provides to your spindles (you may have to enlarge and tap out a couple of the original holes in the spindle (on the cars you did, don't remember about the trucks). Then you use the bolts he provides and bolt the caliper brackets to your spindles. You slip the bearing spacer and seat lip (its a machined part) over the spindle where the drum/rotor runs, and push it back to seat against the back of the spindle (a light taping may be required). Then you pretty much buy and install the rotors with new bearings and seals, calipers, brake pads, and hoses he provides part numbers for.
The most difficult part (which you may not have to do) is drill out a couple existing bolt holes to the next bigger size and tap the threads in the holes. Past that, its pretty much a disc brake job. Gene
Re: 1956 Pickup [Re: poorboy] #2712880
11/05/19 01:07 AM
11/05/19 01:07 AM
Diego-Town, CA
Diego-Town, CA
Thanks Gene, sounds like the way to go!
Re: 1956 Pickup [Re: Diego_Ted] #2713191
11/05/19 10:06 PM
11/05/19 10:06 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Scarebird may make a kit for that era trucks. They have a lot of other Mopar disc conversion kits, so if the other one doesn't work out.....google em and see. Best of luck with the project.
Re: 1956 Pickup [Re: JDMopar] #2713237
11/06/19 08:10 AM
11/06/19 08:10 AM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
When I did the conversion on my '71, I bought the conversion brackets from Scarebird. Got the instruction sheet beforehand so I knew what to order, sourced everything from RockAuto and used slow/cheap shipping, I think I had less than $125 into all Raybestos parts...
Re: 1956 Pickup [Re: nuthinbutmopar] #2713310
11/06/19 11:47 AM
11/06/19 11:47 AM
Diego-Town, CA
Diego-Town, CA
Thanks everyone! Looking forward to getting the truck on the road to make my Ol man Proud! I will need lots of help from the Mopar crowd.
Diego
Re: 1956 Pickup [Re: Diego_Ted] #2713550
11/06/19 11:25 PM
11/06/19 11:25 PM
JDMopar Offline
JDMopar  Offline
After you get him some disc brakes, maybe look into adding power steering. I had a 56 Dodge pickup with a 440/727 back in the early 80's. I had L60-15's all the way around...and MAN, was it hard to steer at low speed! The steering box is about as big as your fist, so it ain't no wonder it was like that.
Re: 1956 Pickup [Re: JDMopar] #2713769
11/07/19 04:55 PM
11/07/19 04:55 PM
Freeport IL USA
Freeport IL USA
Well this is an interesting process. After looking at his posted picture again, the front end of the truck sits a lot lower then it would have stock. Given that the original flat head 6 weighed a bunch (pretty close to the weight of the 440), I doubt the lower front end position is caused by the 440, unless the springs are shot, or several leafs have been removed from each spring.
I guess we (that includes me) all presumed that since the truck has drum brakes it must still have the original beam axle as well. That may not be the case, something has been done to lower the front end of the truck. That could dramatically change what is needed to upgrade to the disc brakes.
It could also make a huge difference concerning adding power steering, which would be difficult with the beam axle.
I guess we need to have Ted look under the front end and see if there is still parallel leaf springs and a beam axle under the lowered front end. It would also be good to know how the front end was lowered if the leaf springs and beam axle are still present. Some of the methods for lowering the beam axle that were used in the past are considered pretty unsafe these days. Gene
Re: 1956 Pickup [Re: poorboy] #2713837
11/07/19 09:14 PM
11/07/19 09:14 PM
JDMopar Offline
JDMopar  Offline
Good eye Gene! You may be right. If I remember right, you can't move the stock beam axle to the top side of the springs on those trucks.
Re: 1956 Pickup [Re: poorboy] #2714276
11/09/19 03:37 PM
11/09/19 03:37 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
A couple of options for power steering, one a little pricey the other not so much if you can find the parts. This is assuming it still has a straight axle under it.
Summit has an electric column kit that works like a lot of new cars do. The cheaper one if you can still find one would be the Ford power assist that uses a ram similar to what Sweptline trucks use except the control valve IIRC is incorporated into the cylinder itself instead of the drag link. Makes it adaptable to anything. Ford used it from the 60's right up to whenever they quit building Grenadas and Lincoln Versailles.
Kevin
Re: 1956 Pickup [Re: JDMopar] #2718135
11/21/19 04:00 PM
11/21/19 04:00 PM
Diego-Town, CA
Diego-Town, CA
Thx for the info guys. The suspension is stock. A question on the.drum brakes, is there a way to adjust? I see no adjustment wheel?
Re: 1956 Pickup [Re: Diego_Ted] #2718165
11/21/19 06:14 PM
11/21/19 06:14 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Cam bolts used for adjustment IIRC.
Re: 1956 Pickup [Re: John Brown] #2718466
11/22/19 08:52 PM
11/22/19 08:52 PM
iagree
Ted look on the back side of the drums, two small bolts (3/8 or 7/16 head size) rotate the cams hidden under the brake shoes, a tiny bit of movement makes them move a bunch compared to the star adjuster wheels used later scope
Those are not self actuating type brakes, the wheel cylinders do all the work. Hence the same size shoes front and back with the bottoms anchor solidly to the backing plate scope
Re: 1956 Pickup [Re: Diego_Ted] #2718478
11/22/19 09:44 PM
11/22/19 09:44 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Thx Diego
Now THAT'S Cool 👍!
Re: 1956 Pickup [Re: Cab_Burge] #2718484
11/22/19 09:56 PM
11/22/19 09:56 PM
Freeport IL USA
Freeport IL USA
Actually, the bottom anchors are also cam offset and will move the bottom of the shoes in or out as well. These brakes are a pita to get properly set, they work great once set, but if they are incorrect, the brakes pretty well suck.
I have a 54 Dodge truck service manual here.
The bolts on the bottom are called the anchor bolts, both are suppose to have either an arrow or a punch mark that identifies the inside position of the anchor bolt.
The adjusting cams under the shoes are referred to as the cam.
the text also refers to the "toe of the shoe" and the "heal of the shoe". The bottom of the brake lining on each shoe on both sides are referred to as the "heal" and the top of the lining on both shoes are referred to as the "toe". Each shoe has a toe at the top, and a heal at the bottom.
From the 54 Service manual:
Major brake adjustment
Be sure the master cylinder is full (paraphrase)
Position the anchor bolts and remove the tire assembly. Remove the inspection cover. Loosen lock nuts and turn brake shoe anchor bolts to fully released position, with the flats of the anchor bolts horizontal and the punch marks on the threaded ends of any pair of anchor bolts together and in line.
(1) Adjust the anchor bolt and cam on one of the shoes to give equal clearance at the toe and the heal. Make sure that sufficent center contact is maintained to produce a slight drag.
(2) After adjusting the clearance on one shoe, repeat the procedure on the other shoe.
(3) After the toe and heal clearance on both shoes have been equalized, install the tire and wheel assembly. Then, using the top adjusting cam, bring the shoe out until a moderate drag is obtained.
(4) Perform this procedure at all four wheels.
The book also goes into detail to be sure the brake shoes are aligned (square with the drum).
It also discusses brake pedal travel. There are 2 long paragraphs about free travel, and travel of the piston required to cover the relief port. Then it covers the travel of the brake shoes to contact the drums, I'll post that last paragraph:
An additional pedal travel of approximately 1 inch is required to move the shoes outward against the drums. The total pedal travel required to set the shoes should be approximately 1 3/4 inches to 2 inches with properly adjusted brakes. A minor brake adjustment (#3 & #4 above) will usually correct excessive pedal travel.
Good luck adjusting your drum brakes. Gene
Re: 1956 Pickup [Re: poorboy] #2718519
11/23/19 12:38 AM
11/23/19 12:38 AM
Still wishing...
Still wishing...
That procedure should be incentive enough to put disc brakes on it. laugh2
Kevin
