How to enlarge ID of bearing?
#2717946
11/20/19 10:34 PM
11/20/19 10:34 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I've cut my column jacket back to the firewall (originally a PS car. Now have manual box and Flaming River U-joint/extension). I bought an "ER-16" bearing that is supposed to work for the lower shaft support... but it won't go on the shaft! After cleaning up all the crud and rust, and polishing with emery paper, the shaft is 1.005" in diameter. I couldn't even drive the new bearing onto it! So I spent considerable time trying to enlarge the bearing ID with a brake cylinder hone in my drill press. I also tried wrapping emery paper around the stones and running that in and out for a while. I didn't measure the ID before I started, but it's now 1.0025 and still won't go on I can't heat the bearing race because it's a sealed assembly with rubber seals. Sanding down the shaft instead isn't a good option because it's hard to reach the place where the bearing will sit (just inside the jacket). I really don't want to take the column apart again (it was enough trouble when I removed the column shift parts and reworked the collar to remove the pointer and shifter nub). And it does not have to be an interference fit because there are two set screws on the bearing to secure it to the shaft. I'm considering taking it to a machine shop. Is there some grinding tool they would have, to enlarge it to 1.006 for a slip fit? Or should I just bite the bullet and disassemble the column, and make the (non-hardened) shaft smaller instead?
Re: How to enlarge ID of bearing?
[Re: DrCharles]
#2717956
11/20/19 11:21 PM
11/20/19 11:21 PM
Posts: 8,869 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
A brake hone with coarse stones should have made quick work of that !! Best done in a bath of solvent to keep the stones clear to cut. Also, don't run the drill too fast.
[Re: Stanton]
#2717961
11/20/19 11:43 PM
11/20/19 11:43 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
A brake hone with coarse stones should have made quick work of that !! Best done in a bath of solvent to keep the stones clear to cut. Also, don't run the drill too fast. I agree with that. Setting that up in a lathe with a tool post grinder and taking off less than 0.002" per side is not super easy. I would recommend a hone to open it up, but being a bearing I would use liberal wd40 and keep the fluid out of the bearing.
[Re: rustbuckett68]
#2718046
11/21/19 11:24 AM
11/21/19 11:24 AM
Posts: 2,637 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Any automotive machine shop has a Sunnen rod hone. He has a .990" mandrel for BBC piston pins. He can hone it out for you in a few minutes.
2011 Drag Pak Challenger
[Re: Stanton]
#2718050
11/21/19 11:35 AM
11/21/19 11:35 AM
Posts: 10,708 North Dakota
6PakBee
North Dakota
You could dick around for days with that bearing. You're probably further ahead to pull the shaft and do a quick grind on it being that its softer material. If you ever have to replace the bearing for any reason, you'll be going through this malarkey again. Decreasing the shaft diameter solves the problem now and in the future.
[Re: 4406bbl]
#2718081
11/21/19 01:06 PM
11/21/19 01:06 PM
DrCharles
West Plains, MO
Success Thanks for the hot tip, 4406bbl I wouldn't have believed it either... so I tried it A couple minutes back and forth, round and round with a 1/2" sanding roll and opened it right up to 1.006 It went on the shaft like butter! Saved me a trip to a machine shop... thanks again.
[Re: 6PakBee]
#2718192
11/21/19 07:46 PM
11/21/19 07:46 PM
Posts: 4,713 Florida
BDW
