Re: One last video for the year [Re: Al_Alguire] #2721398
12/04/19 04:06 PM
12/04/19 04:06 PM
Originally Posted by Al_Alguire
Originally Posted by Cab_Burge
What was the 60 ft times on that run in the video?
Cab it was only 1.051. I struggle on well prepped tracks to get wheelspeed. We needed a bit more extension valving and a tad less air. First hot for me is always a crap shoot at best. My 60's are better on less stellar surfaces where we can build some wheelspeed.
I have seen tires do that also shruggy
Re: One last video for the year [Re: Cab_Burge] #2721671
12/05/19 01:15 PM
12/05/19 01:15 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Cab its simply a LACK of power for me on a killer surface. I can change the 4 link to be a tad less aggressive to but "Shake" is only an issue when I run at divisional events. Usually we can stiffen it up enough and drop the bars and air pressure enough to overcome it. But like I said first hit is always a crap shoot. Its simply a matter of a lack of wheelspeed when the track is really good, can see it in the racepak and on video. On typical bracket prep, or the "no prep" local stuff we have the car very very loose and it works great 1.04 flat is typical in crap air for me in those conditions.
I will be here for the spring fling for sure. Not sure what ill be racing if anything but either way ill be there. We do have a long skinny car too that's quicker than the door car and a better tool for that kind of racing.
Re: One last video for the year [Re: Al_Alguire] #2721740
12/05/19 04:27 PM
12/05/19 04:27 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Al, I bought one of them long skinny things too. LOL. Gonna bring it down along with door car. My son is going to try his hand at Vegas in the door car and I will switch to that long skinny thing. Will look for you. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: One last video for the year [Re: BANDIT] #2721863
12/05/19 09:47 PM
12/05/19 09:47 PM
You and Al are giving me thoughts about naming my S/P door car "Rail Killer" devil
I know, talks cheap so I'll have beat another dozen of them before putting that name on my car whistling stirthepot grin
It is cold outside up here in central OR hence to much keyboard time grin
