Challenger 6.1L cold start problem? #2717865
11/20/19 03:57 PM
11/20/19 03:57 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Have a 2009 Challenger with 6.1L . When cold does not want to idle for about 30 secs unless you help with gas pedal. After that idles, runs fine. Hot starts are fine.
I am thinking maybe IAT sensor, or maybe the coolant temp sensor? Anyone else have any ideas?
Some people you just can't reach...
Re: Challenger 6.1L cold start problem? [Re: Suregrip] #2717900
11/20/19 06:41 PM
11/20/19 06:41 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Hook up scanner and check for codes.
Then check for marginal fuel pressure
Re: Challenger 6.1L cold start problem? [Re: jerseybud] #2718092
11/21/19 01:40 PM
11/21/19 01:40 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
I get the code 050B looks like 0508 but is actually a B at the end. Only throws code when cold at idle... can’t find much on the code...
Re: Challenger 6.1L cold start problem? [Re: Suregrip] #2718115
11/21/19 02:53 PM
11/21/19 02:53 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
Re: Challenger 6.1L cold start problem? [Re: blowndart] #2718268
11/21/19 11:24 PM
11/21/19 11:24 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Looks like P0508 is same as P050B, appears to be IAC related, or a vacuum leak. Could also be IAC valve but car doesn’t seem to have one like older Dodge models did...
Re: Challenger 6.1L cold start problem? [Re: Suregrip] #2718598
11/23/19 12:00 PM
11/23/19 12:00 PM
K
Kiddart Offline
Kiddart  Offline
K
check the gas cap I know sounds weird but that could be your vacuum leak
Thank you
Kiddart
Re: Challenger 6.1L cold start problem? [Re: Kiddart] #2719087
11/25/19 09:01 AM
11/25/19 09:01 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Clean the throttlebody first.
