Re: Bill Mitchell Products. More Mopar blocks
[Re: dthemi]
#2719555
11/26/19 08:21 PM
11/26/19 08:21 PM
Posts: 154 Canada
cuda499
Canada
The main bulkheads are very thin below and between the cylinders. I've only freshend one of these first hand so what I saw was as mentioned, weak in the web, and deck. I have seen 2 broken ones, and one so poorly machined that the rear main seal top, and bottom could not physically align.The broken ones were in spray use, but nothing a good mega block couldn't have taken (maybe 1400hp). Like without a diaper they could have ran the crank over. Some said it was sub par studs, but the look to me was weak block, in the deck too. This is all true
[Re: ZIPPY]
#2721732
12/05/19 03:52 PM
12/05/19 03:52 PM
Posts: 81 Sweden
MikeN
Sweden
The main bulkheads are very thin below and between the cylinders. I can remember two actual complaints...some had paper thin spots that could be broken through easily with a sharp object. (So that means a whole lot more than two were really out there) The response from the ivory tower was, the product was developed using FEA, and the thin areas in the mains were, at that time, considered deliberate. I was also given examples of several builders who deliberately opened up/machined away those thin areas which I was told was for a reduction in Windage losses. This wasn't a debatable topic at that time, and these are not my ideas. The corporate Gods had spoken, LOL. I'm just the messenger so don't shoot. for the price charged, I'd prefer overbuilt rather than under. If the block was computer designed, what strength was specified? Like peak cylinder pressure, torque etc.
[Re: MikeN]
#2721737
12/05/19 04:17 PM
12/05/19 04:17 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
The answer falls under the blanket of "proprietary information".
Note I'm not saying I agree with it, but this is what I was presented with at that time.
Rich H.
Esse Quam Videri
[Re: cuda499]
#2721751
12/05/19 04:52 PM
12/05/19 04:52 PM
Posts: 117 NW Indiana
powertrip
NW Indiana
The main bulkheads are very thin below and between the cylinders. I've only freshend one of these first hand so what I saw was as mentioned, weak in the web, and deck. I have seen 2 broken ones, and one so poorly machined that the rear main seal top, and bottom could not physically align.The broken ones were in spray use, but nothing a good mega block couldn't have taken (maybe 1400hp). Like without a diaper they could have ran the crank over. Some said it was sub par studs, but the look to me was weak block, in the deck too. This is all true I e-mailed Bill Mitchell and got an immediate reply: These new blocks have been proven to 2000 HP with no issues. Sounds strong enough for me, and comes without the Indy attitude, and the extra $1500 for a KB that you can't get anyway.
[Re: powertrip]
#2721774
12/05/19 05:52 PM
12/05/19 05:52 PM
Posts: 2,661 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have a new KB 4.500" bore hemi block (probably 7 years old) and a new Bill Mitchell 4.500" hemi block that I might sell soon. Also 2 NOS iron hemi blocks if anybody needs them. One is 4.500" bore mega block and the other is a 4.19" no lifter machining block. I guess like they use for Super Stock or other high output applications so they can spread the lifters. I live out in the country and am thinking about taking an extended leave of absence and getting a little antsy about leaving such easy to steal items laying out there while I'm gone.
2011 Drag Pak Challenger
[Re: rickseeman]
#2721778
12/05/19 06:04 PM
12/05/19 06:04 PM
Posts: 5,164 CT
GTX MATT
CT
I have a new KB 4.500" bore hemi block (probably 7 years old) and a new Bill Mitchell 4.500" hemi block that I might sell soon. Also 2 NOS iron hemi blocks if anybody needs them. One is 4.500" bore mega block and the other is a 4.19" no lifter machining block. I guess like they use for Super Stock or other high output applications so they can spread the lifters. I live out in the country and am thinking about taking an extended leave of absence and getting a little antsy about leaving such easy to steal items laying out there while I'm gone. Just PM me your address and I will be happy to watch them for you
[Re: cudaman1969]
#2721898
12/05/19 11:45 PM
12/05/19 11:45 PM
rickseeman
Stuttgart, Arkansas
I paid $6,000 for the SS block and I think $6,000 for the KB with freight and I believe $5,800 for the Bill Mitchell. I'm willing to sell them for what I paid. Someone already bought the other block.
[Re: GTX MATT]
#2721899
12/05/19 11:45 PM
12/05/19 11:45 PM
rickseeman
Stuttgart, Arkansas
I have a new KB 4.500" bore hemi block (probably 7 years old) and a new Bill Mitchell 4.500" hemi block that I might sell soon. Also 2 NOS iron hemi blocks if anybody needs them. One is 4.500" bore mega block and the other is a 4.19" no lifter machining block. I guess like they use for Super Stock or other high output applications so they can spread the lifters. I live out in the country and am thinking about taking an extended leave of absence and getting a little antsy about leaving such easy to steal items laying out there while I'm gone. Just PM me your address and I will be happy to watch them for you I would prefer that.
[Re: rickseeman]
#2723146
12/11/19 01:07 AM
12/11/19 01:07 AM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
HI Rick,
Can you msg me the specs on the KB block, (what stage, water or solid, head stud size, lifter size and spread, cam journal, is sleeve OD 4.630" or 4.700")anything else you might think of. Thanks, Ronny
[Re: powertrip]
#2723745
12/13/19 02:09 PM
12/13/19 02:09 PM
Posts: 154 Canada
cuda499
Canada
The main bulkheads are very thin below and between the cylinders. I've only freshend one of these first hand so what I saw was as mentioned, weak in the web, and deck. I have seen 2 broken ones, and one so poorly machined that the rear main seal top, and bottom could not physically align.The broken ones were in spray use, but nothing a good mega block couldn't have taken (maybe 1400hp). Like without a diaper they could have ran the crank over. Some said it was sub par studs, but the look to me was weak block, in the deck too. This is all true I e-mailed Bill Mitchell and got an immediate reply: These new blocks have been proven to 2000 HP with no issues. Sounds strong enough for me, and comes without the Indy attitude, and the extra $1500 for a KB that you can't get anyway. There is no blocks to be had right now, KB or world. Indy doesn't either, and id rather spectate then give them money for that block that has issues staying cool and returning oil to pan.
[Re: cuda499]
#2724238
12/15/19 05:42 PM
12/15/19 05:42 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Bill Mitchell had Hemi and Wedge aluminum blocks at PRI. World did not have an iron block there and an inquiry resulted in "how do you know about that?" and an explanation that they are in the works. No Bulldogs in sight anywhere that I saw.
[Re: CMcAllister]
#2724279
12/15/19 07:20 PM
12/15/19 07:20 PM
Posts: 1,840 NW Indiana
fbs63
NW Indiana
Done
[Re: rickseeman]
#2724319
12/15/19 09:36 PM
12/15/19 09:36 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Probably parts paid for and not delivered. A buddy of mine almost sent money a year ago, based on the information he was given (not by Bulldog) that the issues were resolved, others had received blocks in a timely fashion and a block was available for inspection at PRI. He got cold feet .
[Re: CMcAllister]
#2724334
12/15/19 10:53 PM
12/15/19 10:53 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Picture of guy leaving the PRI show on the Bill Mitchell Facebook group page
[Re: CMcAllister]
#2724352
12/15/19 11:40 PM
12/15/19 11:40 PM
Posts: 764 NW Pa.
KD800X
NW Pa.
Bill Mitchell had Hemi and Wedge aluminum blocks at PRI. World did not have an iron block there and an inquiry resulted in "how do you know about that?" and an explanation that they are in the works. No Bulldogs in sight anywhere that I saw. So are you saying World is going to cast Iron Hemi and Wedge blocks?
[Re: KD800X]
#2724365
12/16/19 01:15 AM
12/16/19 01:15 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Bill Mitchell had Hemi and Wedge aluminum blocks at PRI. World did not have an iron block there and an inquiry resulted in "how do you know about that?" and an explanation that they are in the works. No Bulldogs in sight anywhere that I saw. So are you saying World is going to cast Iron Hemi and Wedge blocks? That's the scuttlebutt. No involvement from Tony. Seems to be early in the process. Guy I went with talked to them. I'll have to ask him if they said anything about an ETA.
[Re: pittsburghracer]
#2724366
12/16/19 01:17 AM
12/16/19 01:17 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Picture of guy leaving the PRI show on the Bill Mitchell Facebook group page That must be really late in the day, given the lack of people. Place was packed all 3 days. Those are the main doors at the front of the hall. That's a high traffic area and the doors are closed. I'd like to know the details.
[Re: fbs63]
#2724381
12/16/19 07:18 AM
12/16/19 07:18 AM
fbs63
NW Indiana
Back
