Page 2 of 5 1 2 3 4 5
Re: What to change about my car for n/a [Re: Clanton] #2717596
11/19/19 04:18 PM
11/19/19 04:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Well, not what my preference would be.
I’d put even thicker gaskets on it.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717601
11/19/19 04:27 PM
11/19/19 04:27 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have an .080 That I have used.My duration on the cam is 260/269 at .050
Re: What to change about my car for n/a [Re: Clanton] #2717602
11/19/19 04:28 PM
11/19/19 04:28 PM
an8sec70cuda Offline
How big is this motor again?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What to change about my car for n/a [Re: an8sec70cuda] #2717603
11/19/19 04:31 PM
11/19/19 04:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Just a stock stroke 440,2.05 ch piston
Re: What to change about my car for n/a [Re: Clanton] #2717604
11/19/19 04:33 PM
11/19/19 04:33 PM
Whew, ok...you have some potential. Thankfully it isn't a 500+" stroker. biggrin stirthepot
CHIP
Re: What to change about my car for n/a [Re: an8sec70cuda] #2717607
11/19/19 04:43 PM
11/19/19 04:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Ya a stroker was too much of a commitment for me,lol
Re: What to change about my car for n/a [Re: Clanton] #2717611
11/19/19 05:18 PM
11/19/19 05:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’d put the .080’s on, and either replace the cam or get it reground.
446, zero deck, .080 gasket, 20cc dish, 72cc head........ 9.08:1
If you got the heads up to 75cc...... then it’s 8.87:1.
If the cam is shorter, then you can make more boost while turning the blower slower......which builds less heat.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717614
11/19/19 05:38 PM
11/19/19 05:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Well that was on the list of options but I wouldn't know where to go with it on lift,dur.I have heavy springs in the heads[280/680#] that I wanted to swap for my old .590 lift cam springs barely used.
ps:The springs on my head are PSI DR1260ML minus the damper spring.
Re: What to change about my car for n/a [Re: Clanton] #2717615
11/19/19 05:43 PM
11/19/19 05:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
The lobe profile and rocker ratio has the biggest influence on how much spring you can get away with(along with how high you need to rev the motor).
For a street/strip car with a roller, there are certainly profiles available that will work and live just fine with less than 280/680.
Re: What to change about my car for n/a [Re: Clanton] #2717680
11/19/19 09:01 PM
11/19/19 09:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Wrong cam for a blower, too hot for your CR.
Boffin Emeritus
Re: What to change about my car for n/a [Re: polyspheric] #2717685
11/19/19 09:10 PM
11/19/19 09:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I will never get the chance to show otherwise so ok.I had fun.
Re: What to change about my car for n/a [Re: Clanton] #2717709
11/19/19 09:53 PM
11/19/19 09:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Here is the 2nd cam I put in my engine back in 2005 SFT
Re: What to change about my car for n/a [Re: Clanton] #2717739
11/20/19 12:03 AM
11/20/19 12:03 AM
So. Burlington, Vt.
So. Burlington, Vt.
That roller could easily be reground to something more suitable for street/strip use a blower, that would also work with lower spring pressure.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717799
11/20/19 10:41 AM
11/20/19 10:41 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I should give Comp a call to see what they say,recommend,cost,turn around time,spring recommendation so I can make a plan going forward.
Re: What to change about my car for n/a [Re: Clanton] #2717818
11/20/19 11:51 AM
11/20/19 11:51 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My goal n/a was to go 11.50 with my current parts but by my results it is not going to happen and my goal has not changed and I will be getting perspective on what that is going to take with low boost on pump gas or mix and not leaving out timing adjustment.As far as cam spec I would think mid .550 lift would be very easy on things and fit ok with low boost to reach my goal.I am just putting this out thinking.
Re: What to change about my car for n/a [Re: Clanton] #2717823
11/20/19 12:07 PM
11/20/19 12:07 PM
So. Burlington, Vt.
So. Burlington, Vt.
You can’t(shouldn’t try to) change the lift very much with a regrind on a roller since there is a good chance of grinding through the heat treat.
If you wanted a roller with .550 lift, you would start out with a different core.
Still, your current roller can be reground into something smaller/milder that would work fine in that application.
You could put the solid back in as well........ it’s closer to the right size....... but wouldn’t make as much power as a correctly sized roller.
Quote
Yeh...... you’re pretty far away from that, and likely not easily cured without spending some real $$.
Cam, gears, converter, and probably headers.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717832
11/20/19 12:51 PM
11/20/19 12:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I like using a solid roller so I will stick with it.I have no idea how much I can regrind the cam to so thank you for your info! and help!I am looking at some roller cam,spring rates just to get an idea of what I may need like the Comp 23-703-9 .582/.588 110 that would need a spring 953-16 200# seat 496# rate and I will test my other springs I have to see if they will work to help plan.I need to have my roller lifters looked at to check their health to re-use.
ps:Here are 2 springs I have .1 is a 943 at 550# inch and the white stripe I am not sure of
Re: What to change about my car for n/a [Re: Clanton] #2718223
11/21/19 09:12 PM
11/21/19 09:12 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I also never understood why you took the blower off. Been mostly street driving mine for over 20 years!
https://www.youtube.com/watch?v=d6wDmNa4g9I
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What to change about my car for n/a [Re: hemi-itis] #2718257
11/21/19 10:42 PM
11/21/19 10:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I wanted to see what it would do n/a and it was easy on the trans while cash was low.
Re: What to change about my car for n/a [Re: Clanton] #2718290
11/22/19 01:23 AM
11/22/19 01:23 AM
I would go with a Comp Cams solid roller cam with 260 to 265@.050 on the intake side with 264 to 270@ .050 on the exhaust side with as much lobe lift tat you can get and have it ground on a 106 to 108 LSA and installed it between 4 to 6 degrees advanced and see if that lights your hind tires on fire or not up grin scope
