Re: A Body Headers
[Re: Cab_Burge]
#2717581
11/19/19 03:42 PM
11/19/19 03:42 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
As I've said before, the Hooker fenderwell headers were a big hit... they hit the tires. They hit the ground. They hit the steering. Etc. Not to mention roasting my (and any passenger's) feet due to the position right behind there. For a drag-only car that you don't mind cutting up, I could see it, but OP wanted street-strip. Tri-Y's are good up to 450(?) hp. They'd be a good but somewhat limiting choice, depending on his plans for improvements later.
Re: A Body Headers
[Re: superwrench]
#2717747
11/20/19 12:57 AM
11/20/19 12:57 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Price a set of custom, stainless and pay more than 2K just for the material. Makes the TTI's a bargain. I don't know how smaller they can make them? FWIW the one's on my 73 Dart Sport 400 B engine are huge. Like 4 ft. long! It's these here. They take up a lot of space and supposedly won't work with power steering. I couldn't get the column gear linkage to work on mine. TTi says MAY need modification. So add $300 for a new cable shifter of your liking if it's auto.
Re: A Body Headers
[Re: Dave Hall]
#2717766
11/20/19 06:02 AM
11/20/19 06:02 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
The B body headers sound like a bargain. Nothing wrong with a cheap header if it works. (works well enough for its owner). Maybe a B body Hedman header but their thicker steel Elite series? Still affordable but more durable than entry level thin tube thin flange Hedmans?
Keep old mopars alive.
Re: A Body Headers
[Re: superwrench]
#2717908
11/20/19 07:33 PM
11/20/19 07:33 PM
Posts: 735 New York
R/T1968R/T
New York
What you will save in $$$$$ you will gain in headaches!! TTI or Proparts. I put Proparts in the Valiant and was amazed how easy they went in.
Re: A Body Headers
[Re: R/T1968R/T]
#2717921
11/20/19 08:30 PM
11/20/19 08:30 PM
Posts: 43,159 Bend,OR USA
Cab_Burge
The new Pro Part A body 2 1/8 inch headers sold by Bob Mazolini are made by TTI for him
