Page 1 of 5 1 2 3 4 5
What to change about my car for n/a #2717470
11/19/19 11:54 AM
11/19/19 11:54 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I took off the supercharger to have less maintenance on the trans and get more use from my car on the track mostly.I am finding a real lack in performance even with my 1050 holley,Victor 440 intake.I have too big of exhaust [2.50" pri pipe]too tight of a converter[stalls at 4k on shift],3.73 gear28" tire et street I will post more info in a little bit.
Re: What to change about my car for n/a [Re: Clanton] #2717481
11/19/19 12:25 PM
11/19/19 12:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
This is what I have done to test after removing the blower to see how things would react.I put on the Victor 440 and an 850 holley and tested at the track and ran 13.80's first with an air filter then a scoop and then put on a 1050 and ran a 13.20ish about 106 mph shifting about 6k where I felt the power drop or felt I should shift it took a long time for the rpm to go up.I feel the exhaust is over scavenging and the vert is hurting me most.I have a street video I will post.
Re: What to change about my car for n/a [Re: Clanton] #2717482
11/19/19 12:25 PM
11/19/19 12:25 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What???
You took away 100hp+ and you car is slower??
Shocking!!
For a street/strip car, it’s all about finding the fastest compromise you can live with.
Heavy car, tall gears, giant headers, big carb....... this isn’t sounding like a great N/A combo.
Make some pretty noticeable changes....... or live with what you have.
I guess I don’t understand the “problem” with leaving the blower on.
They’ve been used on street/strip cars for 60+ years.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717483
11/19/19 12:31 PM
11/19/19 12:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am still debating keeping the blower on under low boost5 or 6 lbs. here is a video
Originally Posted by fast68plymouth
What???
Shocking!!
"For a street/strip car, it’s all about finding the fastest compromise you can live with." Thjis is what I am trying to figure out what I will be happy with.
Re: What to change about my car for n/a [Re: Clanton] #2717487
11/19/19 12:35 PM
11/19/19 12:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
6lbs boost with a roots blower on a street/strip motor should be no problem........ and will save you thousands of $$$$ in the long run.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717489
11/19/19 12:37 PM
11/19/19 12:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I agree VERY much!
Re: What to change about my car for n/a [Re: Clanton] #2717490
11/19/19 12:43 PM
11/19/19 12:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
I never really understood why you took it off.
Re: What to change about my car for n/a [Re: Clanton] #2717494
11/19/19 12:48 PM
11/19/19 12:48 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Hmmmm... I see it (in my twisted perspective) as coming down to two choices:
1. Put the dayum blower back on... and, BTW, how fast was it w/ the huffer on it?
2. Convert what you have to a BradH / PRH replica Victor-headed 440 RB tonguue ... then get some 4.10s and re-stall (or replace) the converter
I'm pretty sure I know which choice is cheaper, unless you've sold off all your blower gear.
As the commercials say: "What's in YOUR wallet?" grin
Re: What to change about my car for n/a [Re: fast68plymouth] #2717495
11/19/19 12:49 PM
11/19/19 12:49 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Survey says,,,,,,
Put the huffer back on, get a chevy trans, and go cat go.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717497
11/19/19 12:53 PM
11/19/19 12:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I wanted to see what it would do n/a .I have a lot of things going on with my daughter,grand kids that involve money so I am evaluating how I need to keep my car to keep using it while I commit to my family.
Re: What to change about my car for n/a [Re: dthemi] #2717498
11/19/19 12:54 PM
11/19/19 12:54 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I can't make the change financialy to a GM for about 6k$ with what my life has going on in other ways.
Originally Posted by dthemi
Survey says,,,,,,
Re: What to change about my car for n/a [Re: Clanton] #2717501
11/19/19 01:00 PM
11/19/19 01:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
Hey..... life happens.
If you’re looking to keep it N/A and go faster....... I don’t see that being all that easy on the wallet.
Of course, it’s running and driving now....... so you don’t “have to” change anything.
If you still have all the blower stuff....... you could put it back on, buy a couple of pulleys to keep the boost low...... drive the car.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717508
11/19/19 01:06 PM
11/19/19 01:06 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I do have all the blower stuff with pulleys to run low boost.I can drive the car like it is if need be and is why I have done what I have to this date.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717521
11/19/19 01:27 PM
11/19/19 01:27 PM
an8sec70cuda Offline
iagree I'd def. throw the blower back on and just spin it slower.
To make it run NA, you'll need to have the converter restalled and change to smaller headers just to start. Possibly a cam and gear change later.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What to change about my car for n/a [Re: an8sec70cuda] #2717533
11/19/19 01:45 PM
11/19/19 01:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you all for your input!I will put the blower back on and run it for 2yrs and see how life goes.
Re: What to change about my car for n/a [Re: an8sec70cuda] #2717535
11/19/19 01:47 PM
11/19/19 01:47 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Without spending a bunch of $$$$...... looks like that number is 13.20@106.
The 106 is good for 12’s...... if the rest of the combo is working.
Cheaper to put the blower back on.
Re: What to change about my car for n/a [Re: fast68plymouth] #2717549
11/19/19 02:33 PM
11/19/19 02:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
There is almost no cost with putting the blower back on and that makes it easier.I may need to go from pump gas to 98 octane maybe in a fuel mix.
Quote
Re: What to change about my car for n/a [Re: Clanton] #2717563
11/19/19 03:09 PM
11/19/19 03:09 PM
If you can get Avgas where you are, that stuff is cheap and works great.
CHIP
Re: What to change about my car for n/a [Re: Clanton] #2717588
11/19/19 03:59 PM
11/19/19 03:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
What’s the current CR?
Re: What to change about my car for n/a [Re: fast68plymouth] #2717592
11/19/19 04:10 PM
11/19/19 04:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am between 9.5 and 10/1 with a 20cc dish piston and Victor heads,.060 gasket.
