Re: What to change about my car for n/a
[Re: Clanton]
#2717596
11/19/19 04:18 PM
11/19/19 04:18 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Well, not what my preference would be.
I’d put even thicker gaskets on it.
[Re: fast68plymouth]
#2717601
11/19/19 04:27 PM
11/19/19 04:27 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I’d put even thicker gaskets on it. I have an .080 That I have used.My duration on the cam is 260/269 at .050
[Re: Clanton]
#2717602
11/19/19 04:28 PM
11/19/19 04:28 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
How big is this motor again?
[Re: Clanton]
#2717604
11/19/19 04:33 PM
11/19/19 04:33 PM
an8sec70cuda
Whew, ok...you have some potential. Thankfully it isn't a 500+" stroker.
[Re: Clanton]
#2717611
11/19/19 05:18 PM
11/19/19 05:18 PM
fast68plymouth
So. Burlington, Vt.
I’d put the .080’s on, and either replace the cam or get it reground.
446, zero deck, .080 gasket, 20cc dish, 72cc head........ 9.08:1 If you got the heads up to 75cc...... then it’s 8.87:1.
If the cam is shorter, then you can make more boost while turning the blower slower......which builds less heat.
#2717614
11/19/19 05:38 PM
11/19/19 05:38 PM
Clanton
northern,Ohio,USA
Well that was on the list of options but I wouldn't know where to go with it on lift,dur.I have heavy springs in the heads[280/680#] that I wanted to swap for my old .590 lift cam springs barely used. ps:The springs on my head are PSI DR1260ML minus the damper spring. I’d put the .080’s on, and either replace the cam or get it reground.
[Re: Clanton]
#2717615
11/19/19 05:43 PM
11/19/19 05:43 PM
fast68plymouth
So. Burlington, Vt.
The lobe profile and rocker ratio has the biggest influence on how much spring you can get away with(along with how high you need to rev the motor).
For a street/strip car with a roller, there are certainly profiles available that will work and live just fine with less than 280/680.
[Re: Clanton]
#2717680
11/19/19 09:01 PM
11/19/19 09:01 PM
Posts: 4,206 New York
polyspheric
New York
Wrong cam for a blower, too hot for your CR.
Boffin Emeritus
[Re: polyspheric]
#2717685
11/19/19 09:10 PM
11/19/19 09:10 PM
Clanton
northern,Ohio,USA
I will never get the chance to show otherwise so ok.I had fun. Wrong cam for a blower, too hot for your CR.
[Re: Clanton]
#2717709
11/19/19 09:53 PM
11/19/19 09:53 PM
Clanton
northern,Ohio,USA
Here is the 2nd cam I put in my engine back in 2005 SFT
[Re: Clanton]
#2717739
11/20/19 12:03 AM
11/20/19 12:03 AM
fast68plymouth
So. Burlington, Vt.
That roller could easily be reground to something more suitable for street/strip use a blower, that would also work with lower spring pressure.
#2717799
11/20/19 10:41 AM
11/20/19 10:41 AM
Clanton
northern,Ohio,USA
I should give Comp a call to see what they say,recommend,cost,turn around time,spring recommendation so I can make a plan going forward.
[Re: Clanton]
#2717823
11/20/19 12:07 PM
11/20/19 12:07 PM
fast68plymouth
So. Burlington, Vt.
You can’t(shouldn’t try to) change the lift very much with a regrind on a roller since there is a good chance of grinding through the heat treat. If you wanted a roller with .550 lift, you would start out with a different core. Still, your current roller can be reground into something smaller/milder that would work fine in that application. You could put the solid back in as well........ it’s closer to the right size....... but wouldn’t make as much power as a correctly sized roller. My goal n/a was to go 11.50 with my current parts but by my results it is not going to happen Yeh...... you’re pretty far away from that, and likely not easily cured without spending some real $$. Cam, gears, converter, and probably headers.
#2717832
11/20/19 12:51 PM
11/20/19 12:51 PM
Clanton
northern,Ohio,USA
I like using a solid roller so I will stick with it.I have no idea how much I can regrind the cam to so thank you for your info! and help!I am looking at some roller cam,spring rates just to get an idea of what I may need like the Comp 23-703-9 .582/.588 110 that would need a spring 953-16 200# seat 496# rate and I will test my other springs I have to see if they will work to help plan.I need to have my roller lifters looked at to check their health to re-use. ps:Here are 2 springs I have .1 is a 943 at 550# inch and the white stripe I am not sure of
