Re: Where to buy Hemi Race Orange in a Qt can
[Re: blewbyu]
#2717358
11/18/19 11:49 PM
11/18/19 11:49 PM
Posts: 21,499 N.E. OHIO, USA
A12
N.E. OHIO, USA
Roger Gibson Restoration (i.e; Frank Badalson) I would call and ask them if their paint is correct for '64 race Hemi (orange)? http://www.rogergibsonautorestoration.com/ "Click here to view our most recent parts catalog (PDF). Give us a call if you have any questions at (804) 275-2155!" Roger Gibson Auto Restoration• 106 State Highway PP•Scott City MO 63780• 573.264.2022•F: 573.264.3821•rogergibsonautorestoration@gmail.com Frank Badalson American Performance• 7622 Whitepine Rd.•Richmond VA 23237• 804.275.2155 •sixpackfrank@aol.com This is what they list in pint cans but only for '66 - '71 HEPP6 Hemi engine paint 66-early 69 …………………………………………... Pint $68.00 HEPPL Hemi engine paint late 69-71…………………………………………….. Pint $65.00 MikeR
[Re: A12]
#2717407
11/19/19 04:33 AM
11/19/19 04:33 AM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
Back in the old days (before moparts lost like 10,000 Members) a reply would come up with a rattle-can or home brew version that would be a dead-on match. Sincerely, Another happy member of the new board. Try the search feature, OP, I know this has come up a few times in the past with a $12 solution.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2717416
11/19/19 07:04 AM
11/19/19 07:04 AM
A12
N.E. OHIO, USA
Back in the old days (before moparts lost like 10,000 Members) a reply would come up with a rattle-can or home brew version that would be a dead-on match. Sincerely, Another happy member of the new board. Try the search feature, OP, I know this has come up a few times in the past with a $12 solution. Personally I have never found a rattle can that ever had the amount of solids to get a good factory type finish as a mix and reduce can and spray-gun/compressor job. Unfortunately good quality automotive paint is expensive now and the only way to do a professional job. Also it will take (sometimes) at least 3-4 $12 rattle cans to do the job well which ends up being $20 bucks short of a can of good mix paint. I've used Frank and Roger's engine paints many times and more than satisfied with the results and well worth the price, just saying. Mike
[Re: blewbyu]
#2717527
11/19/19 01:32 PM
11/19/19 01:32 PM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Somewhere in the archives is a thread about engine paints and there were actual Dupont mix codes you could take to the store to get a quantity mixed be it in a can or an aerosol. There was also some discussion about there being a difference between "Hemi Orange" and the actual engine paint color not actually being the same color at all technically speaking. Whether that is relevant to your Max Wedge engine color or not... Kevin
[Re: blewbyu]
#2717572
11/19/19 03:26 PM
11/19/19 03:26 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I am looking to buy a Qt. of Race Hemi Orange as I believe that is correct for a 64 Max Wedge also. I bought what Bill Hirsch sells but it does not look right. Why? What are you comparing it to?
[Re: John_Kunkel]
#2717671
11/19/19 08:42 PM
11/19/19 08:42 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
Here is the problem. None of the new colors are correct because of the orange tint that goes in the color is not made anymore so they are substituting with other tints to trying to make it the correct color and most of them are off. I am also trying to find the correct color.
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#2717750
11/20/19 01:05 AM
11/20/19 01:05 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Here is the problem. None of the new colors are correct because of the orange tint that goes in the color is not made anymore so they are substituting with other tints to trying to make it the correct color and most of them are off. I am also trying to find the correct color. How would you know how far off from original 50 yr old paint ? This is Mopar Race Hemi orange painted in 1999,today you can hardly see any difference. If I get a chance I'll take a picture to compare and post it.
[Re: John_Kunkel]
#2717778
11/20/19 09:25 AM
11/20/19 09:25 AM
Posts: 4,282 Florida
blewbyu
I am looking to buy a Qt. of Race Hemi Orange as I believe that is correct for a 64 Max Wedge also. I bought what Bill Hirsch sells but it does not look right. Why? What are you comparing it to? Bill Hirsch paint is a more of brighter orange color like the Street Hemi color where the Race Hemi is more on a lighter yellow tint and not as bright.
[Re: blewbyu]
#2717842
11/20/19 01:16 PM
11/20/19 01:16 PM
John_Kunkel
Rio Linda, CA
But, again, how does anybody know what's correct? What are you comparing it to?
[Re: cudaman1969]
#2719632
11/27/19 03:16 AM
11/27/19 03:16 AM
Posts: 1,247 Fremont, CA.
Topcat
Fremont, CA.
When I painted my Hemi, I used VHT high temp grey primer.
Scuffed it wit a 3M pad then sprayed it wit Roger Gibson paint.
No lifting or peeling at all years later.
[Re: mattsmopars]
#2721468
12/04/19 08:46 PM
12/04/19 08:46 PM
A12
N.E. OHIO, USA
I got my race hemi orange from Roger Gibson. It is PPG shop line Enamel. I wanted to put DP epoxy primer on my engine before painting it , but they said not to because it might effect the paint color. I don't really like the idea of painting over a raw engine, just my thoughts that might not properly stick. So looking back I wish that I had just went ahead and put the epoxy primer down and painted it, but we shall see how it holds up. Matt I thought all of the manufactures painted the assembly line engines without primer? Seems the original engine paint held up without primer first.......sure is a pain to remove 40-50 year old factory engine paint down to the bare metal, must be the prep before paint?
