Re: Rear end swap....Need advice/opinion
[Re: 71rm23]
#2716656
11/17/19 11:35 AM
11/17/19 11:35 AM
Posts: 12,305 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
What is it about the leak that makes you think that the housing itself is the problem and not a gasket or seal?
Master, again and still
[Re: DaveRS23]
#2716687
11/17/19 12:35 PM
11/17/19 12:35 PM
Posts: 2,592 None
71rm23
None
What is it about the leak that makes you think that the housing itself is the problem and not a gasket or seal? Because the original housing was bent, cut to straighten, welded back. It has 1 or 2 minor leaks. Overall, the leaks isn't bad but my OCD wants to NOT have a differential leaking.
[Re: 71rm23]
#2716740
11/17/19 02:19 PM
11/17/19 02:19 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Once again OCD rears it's ugly head, I feel your pain but it should be a straight forward swap.
[Re: 71rm23]
#2716760
11/17/19 03:07 PM
11/17/19 03:07 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Make sure there are no residual gaskets pieces or sealer left on both sealing surfaces, on the rear end housing and the mating flange surface on the third member ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) Good luck, to bad about the leaky one. Let us know what you think was causing it to leak after you get it apart ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) BTW, I have had used 8 3/4 seep out of the threads on the lower studs due to the soft copper washers being removed and not reused ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) A good silicone sealer on those threads are your friend ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 71rm23]
#2716815
11/17/19 06:21 PM
11/17/19 06:21 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Like posted above it's pretty straightforward but make sure you get the CORRECT seals and gaskets from doctordiff because he will only sell you the correct seals and any other chassis parts you need for the swap. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 71rm23]
#2717979
11/21/19 01:29 AM
11/21/19 01:29 AM
Cab_Burge
Are you talking about surface rust on the housing or carrier or on the inside of either one of them? I use spray Easy Off oven cleaner after rinsing any car part with cleaning solvent that has had oil or grease inside or on the outside of them. If the rust is inside the axle housing your om your own on that, sorry ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) If on the outside can you get it sand blasted? ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: 71rm23]
#2718022
11/21/19 09:52 AM
11/21/19 09:52 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Any chance you have a Redi Strip within driving distance? All of my big pieces like diffs and Ks go to them. Well worth the time and effort to use them and know that ALL of the grease, oil, rust, gaskets, etc is removed from the entire piece. Inside and out.
[Re: DaveRS23]
#2718052
11/21/19 11:41 AM
11/21/19 11:41 AM
Posts: 2,592 None
71rm23
None
Any chance you have a Redi Strip within driving distance? All of my big pieces like diffs and Ks go to them. Well worth the time and effort to use them and know that ALL of the grease, oil, rust, gaskets, etc is removed from the entire piece. Inside and out. I'll have to see. Good info!
