Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: A few question about the E MW victor head [Re: fast68plymouth] #2716059
11/15/19 11:03 AM
11/15/19 11:03 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Alright, thanks Dwayne.
Re: A few question about the E MW victor head [Re: mopar dave] #2716247
11/15/19 10:49 PM
11/15/19 10:49 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, dropped heads off at Total Flow. Talked to steve awhile and he's a great guy, real nice. I could not get a price from him, so my gut tells me I cant afford him. He doesn't want to shave them, wants me to buy new pistons. Not going that route. I have plenty of shops just down the road that will gladly shave them. He looked at the chambers and said, looks like they all burning the same. Didn't see anything wrong with the head but the large intake bowl and the exhaust port. He said he would try 1 exhaust port massage and flow it, if it helps he will do the rest, if not no big deal and leave the rest alone. There was some massaging between were the intake bowl ends and the seat starts that could use some smoothing. My gut tells me what he wants to do will not make any improvements in my ET, but what do I know. He's the pro at this stuff, so I will see what he gets before I spend too much coin there. Waiting for his phone call. I think best bang for buck is to shave them and bolt back on. I told him what Wilson said about adjusting the intake for faults in the head and he agreed. Said Wilsons is very good at what they do. So, i'm not getting a warm fuzzy feeling as right now.
Re: A few question about the E MW victor head [Re: mopar dave] #2716326
11/16/19 10:48 AM
11/16/19 10:48 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
As I said earlier....... you’ll never be happy with them.
Just find them a new owner and move on to something else.
I agree with the notion that messing with the ex ports won’t yield any ET.
No comments on the valve job?
Re: A few question about the E MW victor head [Re: fast68plymouth] #2716353
11/16/19 12:04 PM
11/16/19 12:04 PM
Mt Morris Michigan
Mt Morris Michigan
I think your right Dwayne. He didn't make a big deal about the valve job, but he didn't seemed surprised by anything. As soon as he started looking in the ports and wanting to make a small change here and there, I knew we were going down the wrong avenue, but how does a hobbiest guy like me tell a professional cylinder head guy he's wrong? I'm gonna let him clean them up and get a better peak at them first. Just waiting for that phone call. My gut is telling me i'm gonna end up spending all my money on something that does nothing. He is not interested in milling them either and that's all I think they need.
Re: A few question about the E MW victor head [Re: mopar dave] #2716634
11/17/19 10:22 AM
11/17/19 10:22 AM
The Great White North
RAMM Offline
RAMM  Offline
I already told you how to "fix" them and yes it involves milling. When I port them the intake port size falls between MW and Standard 440--its closer to Standard 440 just wider, not whole lot taller. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: A few question about the E MW victor head [Re: RAMM] #2716646
11/17/19 11:08 AM
11/17/19 11:08 AM
So. Burlington, Vt.
So. Burlington, Vt.
So, what would something like you propose cost, and how much additional power could be expected?
Would other parts require modification and/or replacement to make use of the head mods?
Re: A few question about the E MW victor head [Re: RAMM] #2716657
11/17/19 11:43 AM
11/17/19 11:43 AM
Mt Morris Michigan
Mt Morris Michigan
Yeah, I told him what you said about how to fix them and he said it would cost more than $5000 to do all that work. I'm not looking to make 800hp or more, so my thinking was a good valve job and flat mill them .045 and call it a day. Wouldn't be much cost and should push my 511 combo near 700hp. I would be happy with that. He doesn't even want to mill them and to me that's the best bang for the buck.
Re: A few question about the E MW victor head [Re: mopar dave] #2716680
11/17/19 12:29 PM
11/17/19 12:29 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
picking up a LITTLE compression & a different valve job is not going to get you 150hp more,,,Just Sayin
Re: A few question about the E MW victor head [Re: CSK] #2717053
11/18/19 09:34 AM
11/18/19 09:34 AM
Mt Morris Michigan
Mt Morris Michigan
I agree with you 100%, but I do think its a step in the right direction. I think the cam is not bad, but a tad on the large side for my compression and I think it will welcome the higher compression with open arms as well as the large ports in the heads and intake if I run the Indy.
Re: A few question about the E MW victor head [Re: mopar dave] #2725729
12/20/19 09:19 PM
12/20/19 09:19 PM
Mt Morris Michigan
Mt Morris Michigan
Heads are back and all cleaned up. Here's a few pics of the exhaust port. Think the short turn needs any work?
Re: A few question about the E MW victor head [Re: mopar dave] #2725730
12/20/19 09:24 PM
12/20/19 09:24 PM
Mt Morris Michigan
Mt Morris Michigan
What ever media he used to clean with looks a bit aggressive as I see a lot of pits in the aluminum. I first thought I may have had some detonation as the chambers are pitted as well.
Re: A few question about the E MW victor head [Re: mopar dave] #2725772
12/21/19 03:45 AM
12/21/19 03:45 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Can't comment on the exhaust short turn without pictures showing the port without the valve.
Not sure what was used to clean up the chambers, etc., but it looks like it almost sand-blasted the CNC machining marks away.
What work was done to the heads?
Re: A few question about the E MW victor head [Re: BradH] #2725781
12/21/19 07:46 AM
12/21/19 07:46 AM
Mt Morris Michigan
Mt Morris Michigan
Cleaned up, guides checked, springs checked, new seals machined .045" off deck, .054" off intake side, no valve job. $800.
Re: A few question about the E MW victor head [Re: mopar dave] #2725795
12/21/19 10:06 AM
12/21/19 10:06 AM
BradH Offline
BradH  Offline
What type of head gasket do you use? The deck surface as it looks in the pics doesn't appear to be smooth enough for MLS now, but I could be mistaken.
Re: A few question about the E MW victor head [Re: BradH] #2725801
12/21/19 10:22 AM
12/21/19 10:22 AM
Mt Morris Michigan
Mt Morris Michigan
MLS. I do have a pair of SCE composites I could use. Gonna get some prep and painting done today and start getting this thing back together tomorrow. I have some cc measuring to do as well.
Re: A few question about the E MW victor head [Re: mopar dave] #2725896
12/21/19 04:47 PM
12/21/19 04:47 PM
Mt Morris Michigan
Mt Morris Michigan
I managed to get a few things done in the garage today and can start getting it back together tomorrow. Some pics of the exhaust port and the valve job Dwayne asked about.
Re: A few question about the E MW victor head [Re: mopar dave] #2725898
12/21/19 04:58 PM
12/21/19 04:58 PM
Mt Morris Michigan
Mt Morris Michigan
VJ pics
Re: A few question about the E MW victor head [Re: mopar dave] #2725900
12/21/19 05:01 PM
12/21/19 05:01 PM
Mt Morris Michigan
Mt Morris Michigan
The machined surface looks quite smooth. almost polished.
Re: A few question about the E MW victor head [Re: mopar dave] #2725904
12/21/19 05:19 PM
12/21/19 05:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
Thanks for posting the vj pics.
Doesn’t look like I did it.
I wouldn’t have left the bottom angle quite that long, and it “looks” like the transition from the bottom angle into the bowl is fairly abrupt.
I would have added another angle there.
The way the radius on the ex seat ends also looks like some flow has been left on the table....... not much, but something.
Looking at it closer...... and keep in mind I’m looking at it on my phone...... the bottom angle looks like it might actually be shallower that 60*.
Re: A few question about the E MW victor head [Re: fast68plymouth] #2725908
12/21/19 05:30 PM
12/21/19 05:30 PM
Pattison Texas
Pattison Texas
I agree on this , also asking Dwayne's opinion, I see no back cut on the intake valve ? I always like to run one up to the lap line.
