1971 Super Bee Emblems?
#2715857
11/14/19 06:19 PM
11/14/19 06:19 PM
Posts: 6,247 JERSEY
RJS
JERSEY
I own a 71 Super Bee and my fender emblems are stick on like the decals. Is that correct??? I added a link to an e-bay ad that claims these with pins are for 70-71. I also have a picture of a supposed original fender and can't really tell but think these may be pin on. Which way is right or is both??? Thanks Ron https://www.ebay.com/itm/1970-1971-...NOS-MoPar-Scat-Pack-Chryco/400976630245?
Re: 1971 Super Bee Emblems?
[Re: 2JcodeChargers]
#2716794
11/17/19 03:58 PM
11/17/19 03:58 PM
Posts: 6,247 JERSEY
RJS
JERSEY
Hi Ron, Previous owner here. The pin type are for the 1970 hood. The hoods heat up for obvious reasons and the tape was not a good method of applying the name badges. For 1971, tape was used on the fender badges, although the font and style of the letter is the same (as least as much as I can tell). I used the factory application instructions for the location, so where those badges are should be pretty close to correct. Hope you are enjoying the car. Chris Hi Steve, The emblems are in the right places but the left side is on wrong per all the research I've done. On the driver's side it should be emblem then decal as you read it. No biggie, since I want to sand and rub the car I figured I'd ask about the pin emblems that all the seller's call 70-71. I done many things to the car over the past couple of years to make it better and better. Ron
[Re: RJS]
#2716807
11/17/19 05:02 PM
11/17/19 05:02 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
On the driver's side it should be emblem then decal as you read it. This is correct as in the photo in the original post. The Bee always follows the emblem.
[Re: T2R9]
#2716866
11/17/19 07:14 PM
11/17/19 07:14 PM
Posts: 6,247 JERSEY
RJS
JERSEY
On the driver's side it should be emblem then decal as you read it. This is correct as in the photo in the original post. The Bee always follows the emblem. Agreed
