Page 2 of 3 1 2 3
Re: Cam recommenations [Re: HotRodDave] #2729285
01/02/20 10:24 AM
01/02/20 10:24 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Apache valve spring at coil bind
Re: Cam recommenations [Re: sixpackgut] #2729363
01/02/20 03:09 PM
01/02/20 03:09 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
All I know is what I did and have done in the past and it works great, perhaps the actual valve lift don't match theoretical, wouldn't be the first time, my good dial indicator sprouted legs and runnoft and now the engine is all together and running. The first one I did is in a 3/4 ton work truck that now has 30,000 hard miles on it and still running great. I know my methods might not always be the most scientific butt the results are that it works. Do you have an assembled engine with that cam you can see how much lift is lost in real world?
Re: Cam recommenations [Re: HotRodDave] #2729513
01/02/20 11:18 PM
01/02/20 11:18 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I have a 6.4 truck motor. Im not sure what size cam is in it. It would be very hard to check. I would need to take it apart and put checker pushrods in it and my shimmed lifters and Im not sure what the cam lift even is on the truck motors.
Honesty, Im at a complete loss. I wouldn't think you would have got 3 miles out of it.
2.015-.080-1.40=.535
Re: Cam recommenations [Re: sixpackgut] #2729668
01/03/20 02:39 PM
01/03/20 02:39 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the 6.4 truck motor has a smaller cam, in between the 6.4 car and 5.7 eagle cam, that is not what I am running. I did have a valve job done on these heads (didn't really need it so just a light touch up) butt most of the other ones I have done did not get a VJ, just cam and spring swap. I pretty much set em all up the same way, shim it to basically coil bind and remove .040 or .050.
Re: Cam recommenations [Re: HotRodDave] #2729810
01/03/20 09:02 PM
01/03/20 09:02 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Unless Im doing the math wrong somehow, there is no way it can work. 40 thousands of problems before full lift is even reached
Re: Cam recommenations [Re: sixpackgut] #2729828
01/03/20 09:36 PM
01/03/20 09:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I'm terrible at math so don't ask me that part, that is part of the reason I do it the way I do.
I got to fart with the VVT hopefully tommorow, maybe if I got enough time I'll pull the valve cover and try to get a measurement of the actual (not theoretical) lift.
Re: Cam recommenations [Re: HotRodDave] #2731298
01/09/20 12:31 AM
01/09/20 12:31 AM
IL
furious70 Offline
furious70  Offline
IL
I just got a used 392 cam for cheap so now I'm really interested in what y'all converge on. Sounds like Ray #1 says no way, Ray #2 used the stock eagle springs but 1/2 the OEM shim height, (or did you used the springs you linked?) and HRD went with 6.4 springs and shims and also made it work?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Cam recommenations [Re: furious70] #2731511
01/09/20 06:13 PM
01/09/20 06:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
check check and double check. I am no good at math so I use the method I described, seems pretty fool proof in my little brain. I have also used them in 5.7s with out pulling the springs and just leaving the stockers in there.
Re: Cam recommenations [Re: HotRodDave] #2731583
01/09/20 09:41 PM
01/09/20 09:41 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
After some research I ordered this spring 68277306AA they were $4,69 per spring. I am told these are the mopar performance spring they sell in the kit for the 5.7 and 6.4. I have not received them yet but when I do I will report on them. I plan to check the pressures etc. I am going to use this spring with the 6.4 MDS cam in the 5.7.
Re: Cam recommenations [Re: biff426] #2731657
01/10/20 09:39 AM
01/10/20 09:39 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Where did you order from because summit and jegs the price is double and triple what you paid. And please report back with coil bind numbers.
For my customers running stock cams such as a 6.1 or 6.4 cam, i have been using stock ls7 springs. Problem with the ls7 springs is they are down on pressure compared to stock mopar springs. But I think even the PAC springs are down on pressure compared to stock springs.
For balls out, I only use the PSI springs. I have used the Comp conical springs in some LS applications. The Comp conical springs have incredible pressures for a single spring
Re: Cam recommenations [Re: furious70] #2731695
01/10/20 11:14 AM
01/10/20 11:14 AM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
On my 5.7 in my 09 we used the stock Eagle springs, when I had the heads redone , we went with the Mopar springs., I'm home today so I'll get a measurement on the spare MDS SRT cam I have .
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Cam recommenations [Re: sixpackgut] #2731755
01/10/20 01:41 PM
01/10/20 01:41 PM
IL
furious70 Offline
furious70  Offline
IL
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Cam recommenations [Re: furious70] #2731860
01/10/20 04:50 PM
01/10/20 04:50 PM
IL
furious70 Offline
furious70  Offline
IL
shipping is a little better with these guys $17
https://parts.moparonlineparts.com/index.php?p=cart
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Cam recommenations [Re: sixpackgut] #2731864
01/10/20 05:10 PM
01/10/20 05:10 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Eastcoast Moparts $69.92 including shipping they delivered today
Re: Cam recommenations [Re: biff426] #2731870
01/10/20 05:23 PM
01/10/20 05:23 PM
IL
furious70 Offline
furious70  Offline
IL
is their a PN for these shims y'all have been talking about?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Cam recommenations [Re: sixpackgut] #2731934
01/10/20 07:37 PM
01/10/20 07:37 PM
Deland, Florida
biff426 Offline OP
biff426  Offline OP
Deland, Florida
Coil bind on these is 1.295 no pressure numbers yet
Re: Cam recommenations [Re: biff426] #2731977
01/10/20 09:42 PM
01/10/20 09:42 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
1.98-.04 shim -1.30 coil bind is .640 -.050, good for .590
I like it. I'll start using them
Could you check coilbind on a bunch of them? For consistency
Re: Cam recommenations [Re: Ray408G3Hemi] #2732092
01/11/20 11:08 AM
01/11/20 11:08 AM
Springtown Pa
Springtown Pa
I came up with .574 (Average) on all the intake lobes,
1996 Viper GTS
Re: Cam recommenations [Re: Ray408G3Hemi] #2732711
01/13/20 02:14 PM
01/13/20 02:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Ray did you check actual valve lift with real springs, check springs or just theoretical at the lobe?
Re: Cam recommenations [Re: HotRodDave] #2733011
01/14/20 03:44 PM
01/14/20 03:44 PM
Springtown Pa
Springtown Pa
Just the lobe..... and base circle , with rocker shaft flex and pre-load in the lifter I would think actual lift is some where in the .560 range, I think pre-load is .060-080 I can't imagine that it would lose more than .01-02 of actual lift in a running engine. I could be wrong I'm a parts assembler when it comes to engines , not builder like some of the guys ...... I know the stock shaft can flex up .0.010
1996 Viper GTS
Page 2 of 3 1 2 3
