Re: CONVERTIBLES AS DRAG CARS
[Re: A/MP]
#2715600
11/14/19 01:13 AM
11/14/19 01:13 AM
Posts: 1,826 South Bend
John Brown
South Bend
FWIW, 1969 rule book says roll bars required in all convertibles, except in stock class.
[Re: cgall]
#2715761
11/14/19 03:31 PM
11/14/19 03:31 PM
Posts: 4,206 New York
polyspheric
New York
I would guess that some major "adjustments" will be needed to install any pre-cut commercially available cage in a ragtop. The top lands where most of the upper halo goes, which means the halo must be narrower/shorter/lower, different intersect angles.
Boffin Emeritus
[Re: 451Mopar]
#2716705
11/17/19 01:18 PM
11/17/19 01:18 PM
Posts: 3,076 Michigan
A727Tflite
Not sure why you would want to run a Convertible? My '69 Coronet Convertible weighs quite a bit more than my '69 Coronet Hardtop. My convertible was built for crusing, but with a mild 505" engine and 5-speed manual trans, it runs in the 13's pretty easy on 255x60x15" BFG Radial TAs (hard street tires), at altitude here in mile high Denver/Bandimere. I think the car is well over 4,000 pounds without driver. Likely to run a certain class, based on factored horsepower and advertised shipping weight.
[Re: A727Tflite]
#2716768
11/17/19 03:24 PM
11/17/19 03:24 PM
John Brown
South Bend
Many years ago people would argue that convertible tops would deform to a shape that was more aerodynamic than a solid steel top. I didn't race with a soft top, so I never got into that discussion one way or the other.
