Alcohol Carb #2713403
11/06/19 03:44 PM
11/06/19 03:44 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Who's your go to manufacturer for an alcohol carb?
Re: Alcohol Carb [Re: DusterKid] #2713404
11/06/19 03:46 PM
11/06/19 03:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
APD
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Alcohol Carb [Re: DusterKid] #2713603
11/07/19 10:02 AM
11/07/19 10:02 AM
412 SB Duster Offline
APD
Re: Alcohol Carb [Re: 412 SB Duster] #2713692
11/07/19 01:49 PM
11/07/19 01:49 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I have one Rupert and an SV1 pro systems. Both work well. APD is also very good. I've heard good things about Gary Williams
Re: Alcohol Carb [Re: DavidDean] #2713693
11/07/19 01:54 PM
11/07/19 01:54 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Re: Alcohol Carb [Re: rt66jim] #2713789
11/07/19 06:33 PM
11/07/19 06:33 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The best ones I've ever seen have been rupert. That goes for NA, and blown. That old guy has a good handle on them working OTB.
Re: Alcohol Carb [Re: dthemi] #2713960
11/08/19 12:55 PM
11/08/19 12:55 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We bolted on a 4150 Quickfuel 950 to replace the Rupert 4500 1050 we had been running. We were actually trying to slow the car down a little because we were creeping up on the limits of our chassis cert.
The car ran the exact same ET and MPH with the 950 as it did with the 1050. The Quickfuel was spot on out of the box and only needed idle mixture and speed adjustments. I am happy with the Quickfuel carb
Re: Alcohol Carb [Re: cl440] #2714103
11/08/19 10:33 PM
11/08/19 10:33 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
BLP or C & S
Re: Alcohol Carb [Re: evenflow] #2714140
11/09/19 07:09 AM
11/09/19 07:09 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I'm sure all the above mentioned companies do great work too. I like dealing with him because he has been at it a long time, and personally cares about what he sells you.
http://www.dragraceresults.com/fullstory.cfm?id=4410&type=9
Re: Alcohol Carb [Re: cl440] #2714242
11/09/19 01:31 PM
11/09/19 01:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
Where you able to jet the bigger carb rich enough to slow the MPH down in the 1/4 mile? If so did you do the same tuning on the smaller carb?
Which motor and heads was this on?
I'm thinking of switching from E85 to straight Methanol also work
Re: Alcohol Carb [Re: Cab_Burge] #2714796
11/11/19 01:23 PM
11/11/19 01:23 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We had 190 square in the big carb. Have not played with jets on the small carb yet.
The engine is a 540" Indy low deck with 345cc 440-1 heads
Re: Alcohol Carb [Re: cl440] #2714929
11/11/19 08:23 PM
11/11/19 08:23 PM
Thanks for sharing that with us up
Re: Alcohol Carb [Re: Cab_Burge] #2714964
11/11/19 09:18 PM
11/11/19 09:18 PM
PA.
"Little"John
"Little"John
PA.
For anyone curious I have 150 jets in my APD coverted 850 dialed in with egt’s.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Alcohol Carb [Re: pittsburghracer] #2722456
12/08/19 06:52 AM
12/08/19 06:52 AM
La.USA
rick4106 Offline
rick4106  Offline
La.USA
Ken Jones
Re: Alcohol Carb [Re: dthemi] #2722490
12/08/19 10:46 AM
12/08/19 10:46 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Sorry, I’ve never used an alcohol carb.
But!
Thanks for that link! I started bracket racing in 1978, and the guys in that article were known to me in Minneapolis. I bet not many know what a device marketed by Ron Folk, known as “The Throttle Wacker”, is. Rupert was certainly in hitter company.
Re: Alcohol Carb [Re: Leigh] #2722588
12/08/19 05:27 PM
12/08/19 05:27 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I have an SV1 also, and it works great and Patrick was accessible and always knew what to do. Have 2 of his gasoline ones also. I had a 1050 alcohol carb done by a fellow in Wisconsin, but it was a POS.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
