AC HOSE ID #2714883
11/11/19 05:53 PM
11/11/19 05:53 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I have 2 NOS AC hoses that I am trying to identify.
I felt this would be the best place to find out since the restoration guys hang out here.
The first hose has GY 13/32 FREON 4755 2667 stamped on it and is 28" long overall.
I am thinking that the 4755 is the vendor code and 2667 is the 266th day of 1967 date code?
The second hose with the muffler has GY 13/32 4769 3286 stamped on it and is 36" long overall.
I am thinking this one has a 4769 vendor code and 328th day of 1966 date code?
The hard part is finding out what they fit and or a part number.
I have seen similar hoses for both but not exact and need your help.
Thanks! John
Re: AC HOSE ID [Re: moparjohn] #2715018
11/12/19 07:30 AM
11/12/19 07:30 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I don’t recall ever seeing any ribbed hose like that on 66-67 cars. Look on the steel crimped portion on one end and you will see the part number stamped. Those could be 76 and 77 hose which is what I suspect.
Re: AC HOSE ID [Re: fastmark] #2715096
11/12/19 12:09 PM
11/12/19 12:09 PM
N.W. INDIANA
N.W. INDIANA
fastmark,
Thanks for your quick reply and information!
I have checked both hoses and only the short one has something stamped into fittings.
The short one is stamped HP9860 on both ends.
Does this match up with a Mopar part number?
Thanks! John
Re: AC HOSE ID [Re: moparjohn] #2715204
11/12/19 06:39 PM
11/12/19 06:39 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Im thinking late 70s ,,,maybe even late 80s vehicles.The ribbed carcass hose was NOT seen on anything up to at least mid 70s
Find someone with a Diplomat or Volare parts book
Re: AC HOSE ID [Re: gtx6970] #2715215
11/12/19 07:29 PM
11/12/19 07:29 PM
N.W. INDIANA
N.W. INDIANA
Thanks gtx6970!
I started looking at pictures of 1977 Mopars with air that have a similar hose for the one dated 3286.
I found a 1977 Cordoba big block 400 car with the same hose coming off the compressor with the muffler.
So that one is solved!
I am still looking at 1978 Mopars trying to find the 2667 dated hose.
Thanks! John
