plastic fuel cell and e85 #2714628
11/10/19 07:57 PM
11/10/19 07:57 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Has anyone had a plastic (RCI) fuel cell dissolve/crumble from ethanol based fuel? This is the 3rd season for my car and suddenly the fuel filters are plugging up in 7 passes Never had a problem until recently. The 10 micron filter after the fuel pumps will start to plug up with a fine black substance. Only other likely source is the inside of the hoses, which were supposedly e85 friendly. Thoughts?
Re: plastic fuel cell and e85 [Re: cagebob1] #2714651
11/10/19 09:30 PM
11/10/19 09:30 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Did you leave the foam in? Maybe a piece was overlooked and left in?
Re: plastic fuel cell and e85 [Re: A/MP] #2714675
11/10/19 11:07 PM
11/10/19 11:07 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
nope, foam was taken out before use. I wish the answer was that easy. I went with a plastic cell after reading about the potential corrosion problems associated with ethanol and aluminum.
Re: plastic fuel cell and e85 [Re: cagebob1] #2714677
11/10/19 11:29 PM
11/10/19 11:29 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Was it a new Cell when you started. Three times now including mine when the holes were drilled by the factory for the fuel fittings they left the turnings inside the cell. What a mess we found. Zero problems in my Duster running alcohol for around five years.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: plastic fuel cell and e85 [Re: cagebob1] #2714705
11/11/19 06:11 AM
11/11/19 06:11 AM
Mo.
racerx Offline
racerx  Offline
Mo.
No problem here with e-85/plastic sell, but I never leave fuel in there over the winter. Been 5 years now.
Re: plastic fuel cell and e85 [Re: racerx] #2714706
11/11/19 06:34 AM
11/11/19 06:34 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Would be more likely a hose lining than the cell, if all the foam is out.
Re: plastic fuel cell and e85 [Re: cagebob1] #2714714
11/11/19 09:09 AM
11/11/19 09:09 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I would bet you have one or more hoses breaking down. I leave fuel in my JAZ cell all the time never a problem
"Just a Bracket car dressed up like a streetcar"
Re: plastic fuel cell and e85 [Re: Just-a-dart] #2714821
11/11/19 02:43 PM
11/11/19 02:43 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
ok, looks like I'm keeping the cell and replacing the hoses. What brand of hose is recommended with a proven record of e85 compatibility. With that said, is there a rule of thumb for the useable life of these hoses?
Re: plastic fuel cell and e85 [Re: cagebob1] #2714952
11/11/19 08:53 PM
11/11/19 08:53 PM
I would step up and switch to the Teflon lined hoses, they will last forever on your deal scope
They are more money but you only have to pay once to start with up
I now only use the Teflon lined hoses on any oil or fuel application now after having to replace some neopreme(SP?) lined gas hoses on one of my old race cars whiney
Same thing on brake hoses also up
